Welding on nuts without damaging them
/ Welding on nuts without damaging them #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
No, not my nuts. :laughing:
I'm making a toy for my 17-month-old son. He loves playing with wrenches and nuts and bolts, so I figured I would make him a plate of metal with some captive bolts and a box wrench on a chain, so he can turn the bolts but neither they nor the wrench could get separated. It's a pretty rudimentary project, and once upon a time, I would have made it out of wood, but I'll take any chance I can get to practice welding.
My idea was that I would drill holes in a plate, then weld nuts over the holes, then put bolts through the nuts, then weld washers onto the end of the bolts to prevent them from being removed. The problem I ran into was, after welding the nuts on, the bolts wouldn't go all the way through two out of the three of them. At first, I thought maybe a little slag or dust got into the threads, but upon closer inspection, they looked like they might be warped or distorted from the heat. For perspective, I used 3/32" E7014 at about 110 amps, DCEP. The base plate is about 3/16" to 1/4" thick and the bolts and nuts are 9/16" (3/8" diameter thread).
As a workaround, I am considering putting the bolts through the plate and then welding the heads of the bolts to the back of the plate, but I really like the idea of having the bolts being turned through the plate, compared to having the nuts being turned up and down the bolts, so I'd rather find a way to affix the nuts to the plate without damaging them. I suppose I could just break down and use JB-weld, but I didn't buy a welder just go turn around and JB-weld something, now did I!
/ Welding on nuts without damaging them #2
Run a tap through the nuts.
Bruce
/ Welding on nuts without damaging them #3
A couple thoughts, 1) use weld-nuts, which are designed to be welded on. Or 2) put a brass bolt through the steel nut that you're welding. The brass and steel won't bond and it may keep the nut from warping.
/ Welding on nuts without damaging them #4
Bruce
Agree with bcp. Use a tap to ream out the nuts.
I have also had success using a impact wrench with larger nuts and bolts. Lube the bolt and run it back and forth several times.
Also, next time you do a project like this, leave the bolts through the nuts during the weld. That will support the nuts from getting so out of round due to heat warping. Just spot weld or tack three of the six faces to lessen the HAZ.
/ Welding on nuts without damaging them #5
You could try the heavy 3/8" nuts, for a 5/8" wrench.....might help. I've successfully welded nuts but never that small 5/8" thread and larger.
Here are some pics of the project.
One side weld. 3/32" E7014.
Other side weld. The second side is a lot neater, I think because the electrode had burned down shorter. If you look at the first side, you'll see it gets a lot better towards the end of the weld.
Top plate. I beveled the plates with a small landing to help with penetration. You can see where I undercut the landing on the top weld, whereas the bottom weld stayed entirely within the bevel.
"Bad" side -- after grinding flat. Small slag inclusion towards the end of the weld.
"Good side" -- after grinding flat. Some undercutting, but otherwise, I'm pretty happy with this bead.
After welding, I beveled all the edges, both for safety and because I thought it looked nice. Not sure how I should have done this if I wanted it absolutely flat. Maybe no bevel? Or another pass?
Finally, I drilled 1/2" holes.
/ Welding on nuts without damaging them #8
Good suggestion! But I don't have a tap. :(
Taps are not that expensive. In fact, if you are going to weld and fab you need a whole set. Harbor Freight has horrible ones for cheap but they work for a few holes if carefully done. They are better than not having any.
That opens another option - tap the holes in the plate instead of welding nuts on the back. One less step and guaranteed to work.
/ Welding on nuts without damaging them #9
I agree, but also a couple of other things, The larger the nut the easier to weld and less likely to be so heat distorted. You can also tack one side let cool, and tack again. Also try just a little less heat (amps). A single tap and a tap handle is not a whole lot of money. You don't have to buy a whole set. Now the best solution. Dont stick them on, TIG them on.. much better control of the process and much better results.. NOT that you cant stick weld small nuts, because you can, and I have done it several times. But given the choice if I had the TIG torch I would use it. On your welds on the plate, you can weave across the puddle a bit and just touch the "toes" of the weldment. This will fill in the gap by making a wider weld bead. I applaud your efforts for tackling the project and getting better all the time.:thumbsup:
James K0UA
/ Welding on nuts without damaging them #10
I cover a bolt's threads in grease then thread that into the nut to be welded. Weld the nut on going easy on the heat (enough so that the nut is well stuck however) then back out the bolt once it cools a bit. Works for me.
Most important thing is making sure the bolt is centred in the bore of the hole. If it's off centre, it will be a bear to get in and out.
See, that's what I said to my partner! I need a TIG torch for this job! She just rolled her eyes. Frankly, I plan to keep practicing stick for a bit before I spend any more money branching out into another process. I have a tendency to do the first 10% of learning on a subject, and in the mean-time buy the first 50% of equipment. Then I move on to the next subject. I've been trying to flip that ratio around.
That is tempting, and if I had a tap set, that's probably what I would have done. I confess I do like the visual effect that having the nuts there would have--so in his little toddler brain, he's seeing bolts going into nuts and associating them. Not that he's not going to figure that all out anyway, mind you.
/ Welding on nuts without damaging them #13
Try to weld the just the steel plate and just get the puddle to touch the nut. Since the nut is not much mass it will heat very easily. Also unless you need to bonded to the steel well just weld it on two sides. If you use a bold to hold the nut make sure to center it and only tighten finger tight (avoid putting stress on the nut). Watch out for splatter. Any on the threads will damage them and if not removed will ruin the threads. Avoid welding stainless nuts if possible. Stainless will gall so even the slightest distortion will ruin the threads. Finally go on ebay and buy some weld nuts, much easier to weld and they aren't expensive.
/ Welding on nuts without damaging them #14
You can make a thread chaser with a bolt, cut 3 or 4 angled cuts in the bolts with a hack saw. When I weld nuts on to a plate, I use a short bolt, coat threads with anti splatter tip paste, run the bolt threw the plate, hand tight. Tack on 3 sides and remove bolt. Nice project for a young mind, they are never too young to learn.
Dave
/ Welding on nuts without damaging them #16
I'd just tack the nuts on...and I'd use TIG welding...easier to concentrate the heat.
/ Welding on nuts without damaging them #17
As others said, TIG is the way to go for attaching nuts that small. And MIG is not bad either.
Are you just tacking them on? Or trying to weld them in full (IE: practicing??) Cause if it were me, I just tack a couple of spots on each nut since it isnt going to be load bearing.
Also, I think 110a is a bit too hot for a small 3/8 nut. With 3/32 rod, I'd probabally run around 65-70a on a DC machine. Maybe a tad more on an AC machine.
/ Welding on nuts without damaging them #18
If you think welding a steel nut on is tough, try welding an aluminum one.:D
Not necessarily a nut, but pipe insert.
2025 Hydraulic Plate Grapple Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
