Broke stem off front tire
/ Broke stem off front tire #1
tripppr
Greenville, TX
Kubota B3300SU
I'm new to tractoring and today somehow broke the stem of the inner tube on the front wheel of my less than 1 year old with about 50 hours on it, Kabota B3300SU. I was using the box scraper to level out a large hump of east texas black clay. The hump is about 30' wide. I would lower the scraper to ground level (tines dropped a single notch below the bottom of the scraper) and make a pass and then dump what got collected at the end of the pass by raising the scraper. In doing so I was making 1 - 2' tall mounds that I would drive the tractor over after each pass.
Am I doing something wrong in my approach of driving over the mounds that would have caused the stem to get broken off? I did not notice low tire pressure in the tire before starting.
/ Broke stem off front tire #2
Driving over the dirt wouldn't break off the stem. Are you sure it is a tube type tire most of the new tractors come with tubeless tires. If a stick or rock hits the stem it can break it, I had to drive my tractor from the back to the front 1/2 mile total with a flat the steam on the tube pulled out of the hole and the bead broke loose all i had to do was pull the tube out patch it pull the thorne out and putit back together didn't even pull the wheel off.
/ Broke stem off front tire #3
it's just one of those things. I can go years and not do it and then three in one week. I bet you don't break another one for a long time.
If they will fit try the meal truck type as replacement.
Yeah, I'm sure it's got a inner tube as it came flopping out. That's how I noticed I was flat. Thanks for the info.
Interesting, thanks for the info. Funny that it broke when I was scraping clear land. I had it back in the woods the weekend before, pushing fallen trees and clearing brush. Would have made a lot more sense that something broke it then.
/ Broke stem off front tire #6
Mine came out so often that i welded a short piece of iron pipe to the rim to protect it. On the threads I put a cap. They won't get hit again.
/ Broke stem off front tire #7
I was going to say the same thing, look at larger equipment most have some sort of protection for the valve stem.
DRIVEWAY ENTRY GATES (A60736)
DRIVEWAY ENTRY...
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A61568)
2018 Chevrolet...
2006 Freightliner M2 106 Terex Hi-Ranger HR46M 46ft. Insulated Bucket Truck (A60352)
2006 Freightliner...
New/Unused Landhonor Webbing Slings (A61166)
New/Unused...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
