Teikas Dad said:Anyone ever use an open deck car trailer for hauling a tractor? Like this:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=289011"/>
This type of trailer is lighter than the wood deck utility trailer and would tow easier with my vehicle.
Diamondpilot said:Problem with that type is its a single purpose trailer. Do yourself a favor and get a flat wood deck.
I use mine to haul tractors, trucks, cars, firewood, lumber, mulch, ect.
Chris
I'm trying to keep the GVW as low as possible. My vehicle will tow 5000 lbs. Tractor/loader/backhoe weighs in at around 3200 lbs according to Kubota specs. That leaves me 1800 lbs for a trailer. I don't want to buy a new vehicle for the few times a year that I'm going to move the tractor. I have a 10' flatbed utility that I can haul just the tractor if I drop the FEL and BH, but I've got some work to do at my camp 270 miles away. I may take a look at the Uhaul car trailers and see if the tractor will fit on one of those. Although, I did see that the trailer weight on some of the flatbed utility trailers were around 1600 lbs for the empty trailer, that may end up being an option. I'm figuring either a 16' or 18' trailer.
I will probably get flamed for saying this, but vehicle manufacturers often under-rate tow capacities.
Why are tow ratings often higher for the same vehicle in Canada, Australia, or Europe?
Metric gravity?
Bruce
No way you are going to safely haul a B3200 on a 10' utility trailer, so get that right out of your head. You need a long deck to balance the load for proper tongue weight, as well as dual axles and electric brakes.
I agree, I tow over my trucks MFG rating quite often. My 1/2 ton has a 5k tow rating and I have no problem towing 6-7k or stopping it with my truck/trailer setup. I towed ALL the time over my 1 tons MFG rating commercially and did so in all 48 states. Its done everyday. I have pulled into commercial truck scales grossing 30k and more with no issues as long as my axle weights were in range. The trailers alone weighed 8500 lbs, stack 15-18k on top of that- trucks and trailers were registered at 36 k gross.I will probably get flamed for saying this, but vehicle manufacturers often under-rate tow capacities. 5001 lbs is not going to break your vehicle or realistically make it unsafe necessarily (though I guess technically illegal). 100-200 over is probably fine a couple times a year. If you were constantly towing it, I wouldn't want to be that close to the rating though. As Roger said though, what vehicle are you using? Not all vehicles are under-rated IMHO. I worry more about suspension/ braking capabilities, though manufacturers tend to go more by engine/ drivetrain capabilities. Many new half-ton trucks are rated to tow more than my older 3/4 ton. They may have more power and equivalent brakes, but they don't have the suspension and rear-end that I have.
A little too much generalization for me... since I borrow a friends 10 foot utility trailer from time to that will haul more than my 20 foot fifth wheel trailer. It has double axles rated at 9,000 each with an extremely short bed and pintle hitch. He bought it to haul marble slabs and it does it well.
David from jax
