Starting a propane generator
/ Starting a propane generator #1
nctacoma
Member
Vermont
Kubota L4330
The other thread below got me thinking that the collective knowledge here could probably help me get this generator started.
We bought a house with a Briggs and Stratton generator hooked up to it. It has a propane conversion hooked up to it and I can't get it to start. I can't find any owners manuals for it so I am at a loss.
It is getting propane when I try to start it. The pull cord turns it over but it doesn't come close to firing. What should I check next? Spark?
Thanks
/ Starting a propane generator #2
You must have 3 things for an engine to run and those are fuel, spark and compression. You need to figure out which is missing and why.
/ Starting a propane generator #3
Thanks
Check to make sure it has enough oil in it. Gens will often have a sensor that will keep them from starting if the oil level is low. Easy to check and fix.
Keith
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
