Generator question wood fired
   / Generator question wood fired #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
I am thinking of how much firewood I have on hand, and How much I should be cutting from my woodlot every year.
I am wondering if anyone has made a wood fired electric generator? It would save my propane for cooking/heating.
I would like to be able to have the unit outside.
Just wondering if anyone has made something like this,
has found plans on making something like this or knows of someone selling something similar.
Just to brain storm,
I am wondering if using wood fired gasification could power a gas genny, or
would I have to go to wood firing a steam system to generate electricity.
I did find this
GenSets
About Wood Gas
***Miniature Wood Gasifier*** - Forno Bravo Forum: The Wood-Fired Oven Community
Thanks
edit**just found this site that has plans http://www.gekgasifier.com/
   / Generator question wood fired #3
   / Generator question wood fired #4
I just looked at that gekgasifier site you linked to, gasification sure has changed since the 80's ;)
   / Generator question wood fired #5
I've thought about the same, but not done any serious research. What would you use this generator for? If you're trying to run your house while the power is out due to the ice storm or heavy rains, it's going to be rough having to keep going outside and stoking the fire under the generator. It also requires some work to get going, so no auto-transfer like you could get with an electric start generator (if wired properly). Or are you looking to offset your electric bill?
With steam or woodgas, there are inconveniences to keep it running. You should be able to come up with a comparison between the two, say kilowatthours per cord to see which is more efficient.
Keith
If you're trying to run your house while the power is out?
Yep what is gettting me thinking this way is seeing the trouble people are having with getting gas, something I can control (wood) would make the difficulties even out. (if I needed to make a windbreak, or a little shed to run it in that would not be an issue.
I understand the work, heated with wood for years and know heating with wood even wood you can cut yourself shows there is no such thing as a free lunch.
   / Generator question wood fired #7
Another idea - why limit yourself to one fuel? set it up for multiples - woodgas, gasoline, propane.
Keith
   / Generator question wood fired #8
Buying that gekgasifier system is $20,000.00 for a 10KW unit. You can purchase a nice one for well under $5k, plus a whole house transfer kit, plus a large fuel storage tanks, plus a fill it with fuel for under $10K. It just isn't cost effective. Plus, if you read it, you have to use wood chips. Not logs. Chips.
I don't think gasification is the way to go.
I would look into steam.... and get a good steam whistle, too. I love steam whistles. :)
I do a lot of spoon carving, so chips of wood are always around:), It is expensive, thats a big negative with it.
I like the multi-fuel idea.
Seems like i need to do some more searching.
New/Unused 20ftx20ft Steel Carport (A48837)
New/Unused...
2013 Ford Taurus SEL Sedan (A48082)
2013 Ford Taurus...
(3) Goodyear 10R 22.5 Tires (A48837)
(3) Goodyear 10R...
2010 Cadillac CTS Performance Sedan (A48082)
2010 Cadillac CTS...
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
1 pallet of power tools (A50860)
1 pallet of power...
