Loader How do you check the hydro fluid
/ How do you check the hydro fluid #1
Chugbug
Central Ohio
BX25
Question??? I check the oil and hydro before every use but I found that when the 3 pt is dumped, the dipstick on the hydro shows too much but when I raised the 3pt it shows dead on. I've been checking the hydro with the 3pt raised and cold. Any thoughts?? Thanks
/ How do you check the hydro fluid #2
Raised and cold is how I always check it. It makes sense to check the level with the hitch raised, since it's assumed that it'll be up when you're servicing the machine and since up is the storage position.
1997 Jeep Wrangler 4x4 Off-Road SUV (A64194)
1997 Jeep Wrangler...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2013 Caterpillar 420F 4x4 Extendahoe Loader Backhoe (A64194)
2013 Caterpillar...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2R ROTARY HOE, 3PT (A64278)
2R ROTARY HOE, 3PT...
