Transport cost?
/ Transport cost? #1
Pops15
IL
Ford 555 TLB, Caterpillar Motor Grader, Kubota L245, Ford LGT 125, FABTEK aerial platform
What's the going rate for having equipment transported on a lowboy? One piece would have to be moved 200 miles and another 270 miles. Pick up and delivery locations are all in Illinois.
/ Transport cost? #2
Around here a one way trip within city limits is $125 using a Land-all. Your probably going to be charged by the mile. Probably about $2.00/mile.
/ Transport cost? #3
I can't answer your question directly but do offer a recommendation. Try wew.uship.com. I've been using it for 3 years now and have had nothing but great luck.
Works like eBay. Post your commodity that you need transported (with weight and dimensions), post the pick-up and delivery locations and finally, post a time frame that you need it done in. Then sit back and watch the bids roll in. Companies will bid on your move. Their bids are available for other shippers /carriers to see and then it starts getting competitive.
I've had terrific luck but make sure to read the fine print with each shipper, check insurance coverage and just like eBay, review their feedback.
Good luck!
/ Transport cost?
I was quoted $800 for a 200 mile haul. Basically $2 a mile loaded, and $2 a mile unloaded for his drive home. Didn't know if that was reasonable or if I should look for someone else.
/ Transport cost? #5
Thats about right. $5 per load mile with a minimum and a load fee is the norm around here.
Chris
/ Transport cost? #7
Wow, I'm in the wrong business!
/ Transport cost? #8
You obviously don't buy diesel fuel, large vehicle insurance, local/state and federal permits! Fill out a log book, are told when you can drive, must stop to get weighed, prohibited to use certain roads!
/ Transport cost? #9
A rule of thumb we always used was roughly the cost of a gallon of fuel per loaded mile. So if diesel was $3.99/gal it would be $4 a loaded mile. Sounds about right.
/ Transport cost?
Thanks for the replies.
/ Transport cost? #13
Actually, yes, yes ( depends on your definition of large), no and no.
I don't haul as a job. Just an occasional help out a friend haul, a couple of miles usually or just for myself.
I thought $2 was good, but after reading about those that are self employed doing it, I understand the $4 or $5 a mile due to insurance costs and the above mention of permits. I also realize that there isn't a lot of profit even at that rate.
/ Transport cost? #14
A few months ago I had a 1949 John Deere B tractor hauled 400 miles on a gooseneck. Cost me $350. Price was low because the tractor (which weighs about 4300 lb) could be driven onto the trailer (so no problem loading/unloading) and the hauler was deadheading home until I found him and gave him the load.
1992 21ft Four Winns 205 Sundowner Boat with 21 Ft. S/A Boat Trailer (A61574)
1992 21ft Four...
BALDOR INDUSTRIAL 15 HP MOTOR (A64281)
BALDOR INDUSTRIAL...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2025 Mini Excavator Rake Attachment (A61572)
2025 Mini...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
