Change P/S Fluid
/ Change P/S Fluid #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
My 2007 Tundra has almost 115k miles, when I ask about changing the P/S fluid (ATF). The mechanics tell me it is not necessry. What do y'all think?
/ Change P/S Fluid #2
I think it's a good idea. I use a MityVac to suck out and replace about 7-8 ounces every time I do an oil change on my vehicles. I've never had a power steering problem so I believe it helps by keeping the fluid fresh.
/ Change P/S Fluid #3
To be totally fair, I have been driving for over 25 years and have only had 1 power steering issue on a Ram Truck and it was when it was fairly new. Cant remember the miles but it was around 15,000 so it had to be just a bad part from the factory.
You are not hurting anything changing it but I agree its really not necessary.
Chris
/ Change P/S Fluid
Thanks for the opinions guys.
/ Change P/S Fluid #5
If you have a worm and roller steering gear box a fluid change is not going to hurt. If it is a rack and pinion then I strongly recommend a fluid change. The rack and pinion's seem to have more wear internally. Most of the steering gears and pumps we replaced on rack and pinion systems were due to metal contamination. On my vehicles I flush the PS at 15k miles or 1 year whichever comes first.
Has it helpued? Don't know, but I haven't had to replace a steering gear or pump on my own vehicles in over 20 years.
Just observations from 35 years in the auto industry.
Ken
/ Change P/S Fluid
Ken
It has rack and pinion, thanks for your help.
/ Change P/S Fluid #7
I think of it this way - it is a hydraulic system that also lubes gears. Why wouldn't you want to change it? Frequency doesn't need to be much - 50-75k is probably a good figure, but even 100k is more than most people do...
/ Change P/S Fluid #8
Bob - pls don't take this the wrong way - just make sure that it is the correct fluid.
Particularly on some newer vehicles, the wrong fluid can cause you major headaches. Given the correct fluid, I'm all for changing it, esp. with rack/pinion setups.
If you are planning to keep the truck a long time, consider something like a Magnefine filter.
Magnefine Inline Transmission Power Steering Filters
Other than being a customer, I have no connection to Magnefine.
Rgds, D.
/ Change P/S Fluid
Rgds, D.
You are absolutly right, I have seen people put the wrong fluid in. Thanks for your help.
/ Change P/S Fluid #10
Have been thinking of doing fluid changes and I am supprised none of the manufactuers address this issue. When ever I do brakes I flush as much as possible out as brake fluid absorbs alot of moisture.
Yes do make sure, have a Chrysler T&C van and it uses ATF+4 for fluid as with the DODGE Ram. Now the JEEP Commander Limited with a HEMI use Mopar Hydraulic System Fluid as the power steering also drives the cooling fan, mixing incorrect fluids can do damage and the dealers do not always know the correct fluid.
David Kb7uns
/ Change P/S Fluid #11
I typically flush mine out at about 30K miles or so. Well, not really flush. I use a turkey baster and suck out the old stuff and replace. Its easy and you'll be amazed at the junk that accumulates.
I began doing this after losing a seal on a steering box in my 2001 F150. It had really low miles at the time and I was the orginal owner. But the steering shaft at the seal interface looked like it spend a few years in the Atlantic. It was the lowest point in the PS system, so I think it held internal and external contamination. Never had a problem again with any other vehicle.
/ Change P/S Fluid #12
It's a toyota, I wouldn't worry about it. :D
Honestly, my '97 Tacoma had 270,000 pretty hard miles on it when I got rid of it and I never did a lot of the things Toyota called for. The truck was still in excellent mechanical shape at that mileage. I changed the oil and filters regularly, trans/t-case/axle lube, plugs and wires, brakes, etc but that was about it.
2018 Chevrolet Cruze Passenger Car, VIN # 1G1BC5SM5J7145503 (A61165)
2018 Chevrolet...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2016 Jeep Patriot SUV (A61569)
2016 Jeep Patriot...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
