Just Bought a New Kubota
B2920 with Turf tires, it got delivered with Kenda's Turfs in the front and Goodyear turfs on the rear both with different treed's too! Not that its a big deal, but I figured a new tractor would come with matching tires, the dealer says thats how kubota's B series are coming out with, any input will be appreciated!!!
I've long been an advocate of turf tires for compact tractors....can't hardly believe it's been more than 30 years now! Anyway, three of my four machines have them, and the other one will too some day.
Apparently there are several options in turf tires for your tractor. I don't know the exact brands and differences, but agree that if it was important to you then the dealer should have explained it. A few hours of use on a tractor tire won't make any difference. If it was me, I'd ask to see what options you should have been shown and at the same time I'd ask what kind of cash it would take to swap....if you want to. But you may not. Read on and I'll say why....
What is really important in any 4wd is getting the ratio of the tire's rolling circumference correct to match the internal gear ratio in the transmission. That needs to be correct between the front and the back tires. If they need to go to different brands to accomplish that then so be it. You can check that by shifting between 2wd & 4wd.
Some tire thoughts:
1. If you are going to be in snow or mud, get some chains for your turf tires. Don't go aggressive; go to a modest or small size chain link but with lots of crossing bars. It doesn't take much of a chain to make a huge difference and the more crossing bars it has the longer it lasts and smoother it runs. My favorite chain is composed of small chain links with the crossing bars in an X patterns joined in the center. An good X pattern chain can run almost as smoothly as a tire.
2. Unless you are only doing mowing on golf putting greens then you don't want Galaxy (diamond tread) type of golf course tires. Those tend to be a taller, narrower type of turf tire with almost no traction at all. You lose the traction and don't gain the center of gravity advantage.
3. If you are doing a lot of work in the barnyard or on dirt then consider industrial tires. They are a good compromise between turf and Ag type tires. Wear like iron, too.
4. Final thought..... If what you have on your tractor is the option with standard low profile wide turfs I'd just run those tires. You aren't going to do much better than what you have right now. Unless you are not going to mow at all and need the industrial tires there just is not enough difference to be worth a change. A basic turf tire will last a couple of decades in normal use. And your back will thank you. At least you got away from the Ag tires.....in my opinion with a compact tractor you have already gained most of the tire advantage by simply using something other than Ag tread.
enjoy! rScotty
