Adding remotes on L3940HST
/ Adding remotes on L3940HST #1
rogerius
ON, Canada
Kubota L3940HST
I'm preparing for a new winter project: adding remotes on my L3940HST. Working all summer with the box blade, I saw how much extra work I was doing just to adjust the box blade: tilt the box up, tilt the box down, keep it horizontal, etc. so I decided to added 2 remotes just to TnT my box blade.
The dealer quoted $1350CAD just for parts. This will include 2 floating valves with levers and couplers. Is this price okay?
Thx.
/ Adding remotes on L3940HST #2
I paid $718usd for the 1st valve when I took delivery of tractor, and had the 2nd added for $426usd a few months later. Parts and labor by local Kubota dealer. I had them space the levers out so they were easier to manipulate. Philip.
Can you please confirm the valves which you have are floating style? I remember somebody here said the floating valve are little more expensive.
/ Adding remotes on L3940HST #4
1st set, L8335-20 and L8309-2. 2nd set L8336 and L8308. None of them float. Philip.
/ Adding remotes on L3940HST #5
Thx.
It's all about cosmetics. I put a dual-remote setup on my tractor a couple of years ago to run a snowblower chute. I paid a little over $200 for a dual-spool valve, and maybe another $100 for hoses and couplings. Float or non-float is irrelevant - its just another valve option - cost is similar. The exorbitant cost quoted to you should (I would hope) result in a clean and factory-looking installation that doesn't look like you built it in your garage. Can't say the same thing for mine.
JayC
I just received a quote from our friends from south as $1150US. Seems you guys has different prices there. Now I'm still thinking in what direction to go as pay more and have a Kubota factory style or pay less (I don't know how much yet) and have an exposed valve. I checked the forum but I didn't see any non-Kubota valves instaled on a L3940. Do you have any recommendation for valves and couplings in order to check the exact price.
Thx.
/ Adding remotes on L3940HST #7
Thx.
You might want to contact MtnViewRanch as he sells Fit-Rite I believe.
I had three OEM remotes and TnT on our last tractor.
/ Adding remotes on L3940HST #8
Is that $1150 shipped up to you? The shipping will not be cheap. :( You get what you pay for, you can do a pretty nice aftermarket setup for $600-$800, but it will still be an aftermarket setup and IT WILL NOT be close to appearing like the OEM set.
No shipping cost included. That will be a fortune with taxes maybe some duty, etc... I'm at 1 hour drive from the border so I can pickup from there.
/ Adding remotes on L3940HST #10
If you can afford the OEM units, that is the way that I would go myself. Be sure to get at least one of your valves with the float function if not both of them. ;)
2016 FORD F-150 (A67714)
2016 FORD F-150...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
FUEL TANK (A68842)
FUEL TANK (A68842)
2014 Ford Escape AWD SUV (A66738)
2014 Ford Escape...
