neutral start switch
/ neutral start switch #1
glgeek
minnesota
X728
greetings
would someone know where the neutral start switch is located on an x728 2012?
also, is this wiring harness just supposed to be hanging out unsupported like this?
TIA
/ neutral start switch #2
the wiring harness is normal, supplies power to the PTO solenoid.
I'm not sure there is a neutral start switch, just need the brake depressed for start, and PTO off.
are you having trouble starting the tractor?
no, the tractor starts as it is supposed to. just fiddling with some stuff.
Arrow Quip 7500LMR Cattle Chute w/ Head Holder (A64047)
Arrow Quip 7500LMR...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2020 DRAGON 150BBL ALUMINUM (A63569)
2020 DRAGON 150BBL...
2017 TOYOTA TUNDRA(INOPERABLE) (A63569)
2017 TOYOTA...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
