2305 No Lights / Wont Start without jump
   / 2305 No Lights / Wont Start without jump #1
dmfahie
Member
Limington, Maine
J.D. 2305
Good afternoon. Im a bit confused by whats wrong with my 2305. Out of the blue, I have to jump it to get it started. Then on top of that lost my headlights. The dash lights and blinkers work, but not exterior. Im lost here. Checked fuses, all set there. Any ideas?
   / 2305 No Lights / Wont Start without jump #2
We are on our third battery in four years.
Thanks for the reply. Would a dead battery effect the lights even after I jump it and its running?
   / 2305 No Lights / Wont Start without jump #4
Take the battery to a battery sales location, that has a means to load test the battery with a carbon arch tester. The battery in all likelihood will fail the test. If it does not fail, you will know it can be ruled out in future testing for the cause of your problem.
Would the battery explain the lights as well?
   / 2305 No Lights / Wont Start without jump #6
Yes, it would...
You might get lights with a bad battery (lights come on, but the tractor won't crank fast enough), but when you don't even get lights...that's indicative of a bad battery.
   / 2305 No Lights / Wont Start without jump #7
I'd suggest to check all 4 battery cable connections and alternator output when engine is running.
   / 2305 No Lights / Wont Start without jump #8
When connected to the jumping battery, does the lights work then? If so, I would agree either bad battery or terminal corrosion somewhere that is either not giving you enough ground or good enough contact. By all means a simple battery test should help deduce the problem to either a connection issue or a real battery issue.
   / 2305 No Lights / Wont Start without jump #9
Had the same exact thing on my 2010 with 140 hours on it. Turned out to be the battery.
Only thing I would add is mine couldn't be jumped nor would it take a charge. Good luck
   / 2305 No Lights / Wont Start without jump #10
Is the alternator showing proper output? Are your battery connections tight and clean? Is the tractor outside during sub freezing weather with a low battery?
12ft. Flatbed Truck Body (A59230)
12ft. Flatbed...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
26120 (A56859)
26120 (A56859)
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
