Snow Clearing Technique, what is yours?
   / Snow Clearing Technique, what is yours? #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I don't think this has been covered here, but it is near the season. So what attachment do you use, tire type, chains and techniques? We don't get much snow in VA, so my technique may need improving.
   / Snow Clearing Technique, what is yours? #2
I plow several long driveways. Mine is actually the shortest by far. Fortunately given the snow we get here, on my driveway and one other, I can push all of the snow to the downhill/downwind side. That way, I have no banks of snow catching the drifting snow. Here, studded chains make life much easier. I use an 8' truck snow plow with an attachment plate welded to the frame. My modified auxiliary PTO controls the angle of the plow. I start my runs pushing the snow to the side I desire. The next run pushes it past the edge of the driveway. Where/when possible, I make another run pushing it much further. Where I do not have lots of slope to push snow down or if there has been a large snowfall, I make a run making holes in the banks by making 45° pushes with the plow, shoving the snow further back every so often. This is more difficult on the longer driveways since they did not cut the trees back far enough so the trees are right to the edge of the driveway. Then I make another "normal" pass, the plow dumping the snow into these "holes". Keeping the edges pushed back is important because we can get many feet of snow with no thaws for months. For an 8" snowfall, it takes me about an hour to plow 4 driveways with a total length of over half of a mile.
Ken
   / Snow Clearing Technique, what is yours? #3
I use the 60" power angle snow blade that I bought with the PT425 back in 2001. First pass is usually with the blade straight and I run straight down the center of the driveway. The snow piled up in front of the plow tends to form wedge and pushes most of the stuff off to both sides as I go. When I get to the street, I back up from the pile and go around it, out into the street, turn around, angle the plow to the right and make a second pass back to the garage. Turn around again, leaving the plow at the same angle it is already to the right, make my third pass back to the street. Then all I have to do is clean up the small piles at the street and garage end and I'm done. That usually works well for most snowfalls we get here. However, snowfalls differ each time. 18" of fluffy stuff can take 10 minutes while 6" of wet stuff can take 45. Also, I like to avoid large windrows of snow on each side of the drive, as SpringHollow mentioned, it can lead to drifting over in high windws. Nothing more depressing than plowing your drive to 4' snowbanks on one side and waking up to 4' drifts all the way across your drive the next morning.
So, if more snow and high winds are expected, I tend to push all of the snow back to the rear of my driveway an put it all in one HUGE pile where it won't drift over the main driveway. Also, I like to avoid large piles of snow on the ends of my drive near the street. It tends to block views when backing the car out.
The beauty of the Power Trac is the power angle snow blade that can lift 60". Man, you can really stack the snow up high and fast with that thing. I keep getting tempted to get a blower, but cannot yet justify the cost, as we only get a few heavy snowfalls each year on average.
I will say after 10 years of using the PT plow, it is starting to show the signs of wear. The corners are getting bent back now. I may straighten it and re-do the cutting edge.... some day..... maybe...... :laughing:
Ken
Thanks for the techniques. How have you modified your AUX PTO?
Moss, I never thought of going down the center with the blade straight. I think I will try that.
   / Snow Clearing Technique, what is yours? #7
Pray for Spring.:D
   / Snow Clearing Technique, what is yours? #8
A combination of the first 2 tractors shown.
   / Snow Clearing Technique, what is yours? #9
You better not let that little white fuzzball outside in the winter.... too cute!
   / Snow Clearing Technique, what is yours? #10
Yeah, it works great in average snows. Wet heavy stuff, though can stop the 1500 pound tractor pretty quick. Then its just a matter of pushing it at 45 degree angles (with the blade still straight) off the sides every time the tractor starts to slow.
   / Snow Clearing Technique, what is yours? #11
Meyer 7.5 ST Snowplow attached to my 2001 GMC Sierra, supplemented by LA 181 FEL on my BX1500 for the tight spots and final cleanup.
   / Snow Clearing Technique, what is yours? #12
I have a 100 foot driveway and also plow the neighbors. I usae the same procedure that Mossroad does to start the plowing. I use turf tires and have never had a problem with traction even when plowing 6 inches of the wet stuff.
Tractor and plow ready and waiting as the first snow is expected next week.
PJ
   / Snow Clearing Technique, what is yours? #13
I have a 100 foot driveway and also plow the neighbors. I use the same procedure that Mossroad does to start the plowing. I use turf tires and have never had a problem with traction even when plowing 6 inches of the wet stuff.
PJ
   / Snow Clearing Technique, what is yours? #14
Did you see this adorable little fellow over on the Dog Pics thread in the photos section ?
Hi my name is Buttons because I'm cute as a button.
I heard a lady at the farmers market say _ My what a cute little dog-isn't he beautiful so I know it's true.
He is part Pomeranian and part Pekingese and is better looking than his mom and dad put together.
This lovable little creature belongs to my wifes step mother.
We have been dog setting him since the last of May while his owner recovers from 2 way heart bypass surgery .
   / Snow Clearing Technique, what is yours? #15
here are my 2 toys
   / Snow Clearing Technique, what is yours? #16
When I get up in the morning I look out and see if we got any snow, haven't had a bad winter since 1978, so I am surprised if we have very much accumulation. If not very much it will usually melt away fairly quickly. If it is deep then when I go out to push it off with the snow blade. I take the pt off the twinkle charger get in the cab of my pt 425 close the doors start the tractor push the garage door opener and then back out. I then go up to the driveway and back drag the snow away from my upper garage where the driveway gate opens. I then push the snow to the center of the driveway from the upper carport to the carport in front of the house. I then back up on the carport and push the snow out the driveway and over the hill and most of the snow rolls into the creek and is immediately gone. I do have to push the snow across the road so I have to watch for traffic which is very light traffic but there are some that makes you think they would run you down [fried brains I believe]. Last year we didn't get any snow to the extent that I needed to remove it from the driveway I don't believe. In the areas where the rest of you live does it seem like the winters are getting milder or worse? I shouldn't have mentioned our mild winters, we probably will have a bad one this year, shucks!
   / Snow Clearing Technique, what is yours? #17
Whatever I do I try not to go over the same spot twice to save space.
   / Snow Clearing Technique, what is yours? #18
My PT1460 is an animal with the plow. The rubber edge that I got with is is really nice too. I finally got the driveway paved this year, and can't wait to try the PT on it.
   / Snow Clearing Technique, what is yours? #19
Well that made absolutely no sense! I meant to say I try not to go over the same spot twice to save TIME!
:cool2:
   / Snow Clearing Technique, what is yours? #20
Quote Originally Posted by MossRoad View Post
Trying to save the space/time continuum!
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56438)
Adams Load Out...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
