Rear Blade Rear Blade for JD 5303
/ Rear Blade for JD 5303 #101
Nice work Big D...
As jenkinsph said, there isnt much curve at all there, I can see that blade being really flimsy before you beefed it up.
Blades that dont have any backbracing (like you added) only have the curve to give them strength. Without much curve....:confused2:
A small tractor like yours would have no trouble bending a blade even if it was made with 1/2" plate if there is no curve. Plate steel isnt strong in the direction used for a blade. They need either curve or a strongback to give depth for strength.
/ Rear Blade for JD 5303 #102
Steve, those braces will help a lot. But you know that it is just a temporary thing before you get the LP RBT3584. ;)
Brian, I agree 100%, the LP3584 is a Brute of a blade don't believe you could bend it very easily. It took me three different blades over the years to finnily get it, but now it will be my last blade I buy(Ihope).
DevilDog
Picked up blade this evening. Straightened moldboard after removing cutting edge. Straightened 3pt hitch and boxed in bottom. Straightened bend in 3pt top link area. Wound up using 8"tubing split and installed across back of moldboard. Replaced cutting edge with used grader blade bolted on.
Next phase sanding and painting. This phase will take me a little while.
/ Rear Blade for JD 5303 #105
Looks good, very substancial I think. A little suprized how he handled the tapered ends, I would have tapered down to about 1 1/2 inches and then used a piece of heavy flat bar torched to the same curve as the moldboard fitted against the tubing. This would have been a full height stiffener rib.
Doesn't really matter now because that blade will last you a long time now and be tough enough.:thumbsup:
/ Rear Blade for JD 5303 #106
looks sweet.
but no pics of where you boxed the underside:mad:
Was not quite what I expected, but think it will be adequate. This gentleman takes a lot of pride in his work and I try to be sensitive to this and not be overly critical. I would have preferred the grader blade have been cut square before attaching, but the function is not affected.
looks sweet.
Ran short on time yesterday evening and didn't get to take all the pictures I would have liked to. It may be this weekend before I get time to look over more closely in daylight.
LD1 said:
looks sweet.
Here are pictures of bottom side of 3pt hitch.
Went back over drive today and this time it cut right through places where last time it skipped over. Could be new blade or extra weight or combination of both.
/ Rear Blade for JD 5303 #110
Very nice and very well done. There are only two things left I would do, and they will cost you LESS than $5 bucks.
Fill in the end of the main beam, and fill in where the nut for the pins are.
I would do this with a simple can of expanding foam. It is cheap, and can easily be removed to get at the pin nut if need be. This will prevent bees. I tell you, it is a rude awakening when hooking up the blade and have a swarm of mad bees coming after you:confused2:
Had a little time over the long weekend and was able to get paint on. JD dealer was open on Memorial Day and swung by to pick up extra paint needed and ordered some stickers. Hope to have this completed within the next two weeks.
/ Rear Blade for JD 5303 #112
Looks better than new and is for that matter.
Have ordered a few of what I believe to be the original JD stickers that go on each side of the upright where the top link mounts. Looks like there is the number "45" on the right side of back of blade but unsure if anything is on the left. I have found one picture online of what appears to be a similar blade in fair original condition. Does your blade still have the original stickers on it that I could use for a reference? It probably means little in the whole scheme of things but I would like to put the original stickers back on it if possible.
/ Rear Blade for JD 5303 #115
Here is the best picture I have of the rearblade hope this helps you.
The sticker on the far left, any idea what it is? Going to try dealership to see if they can pull up any old information on what they would be.
/ Rear Blade for JD 5303 #117
It is a caution stick IIRC, I can get a snap shot of it but it will be a few days before I can get it for you.
I called local dealer today and the stickers are no longer available. As is evident in how long it has taken me to work on this project, I am in no hurry, but would like to get it right. Would you mind taking picture of rear of blade to show which decals are on the blade and also the size? I am considering just having them custom made since I can't order them.
/ Rear Blade for JD 5303 #119
Will do, working in town for the next couple of days while my equipment is at a customers ranch.
