Tractor Sizing How much?
/ How much? #21
So you guys pulling over 10k, do you all have commercial drivers licences? I thought that pulling a 10,001lb trailer required a CDL. :confused3: Or do you just stay off of the Interstates?
Some states have a Farmer exemption.
/ How much? #22
Only in CA.
You wouldn't need one either for interstate commerce.
/ How much? #23
Only in CA.
Are you sure? From what I can find, pretty much every state has a different license to pull a trailer over 10,000lbs. Makes no difference to me, just don't want people getting in trouble. ;)
Wisconsin
Driver龍 licenses are separated into the following classes:
class A: Commercial license permits the operation of any combination of vehicles with a Gross Vehicle Weight (GVW) rating of over 26,000 lbs. if the GVW rating of the vehicle or vehicles being towed is in excess of 10,000 lbs.
class B: Commercial license permits the operation of any single vehicle with a GVW rating of over 26,000 lbs. and any such vehicle towing a vehicle or vehicles with an aggregate GVW rating of 10,000 lbs.
class C: Commercial license permits the operation of any single vehicle with a GVW rating of 26,000 lbs. or less, including any such vehicle towing a vehicle with a GVW rating of less than 10,000 lbs. if the vehicle is designed to transport more than 16 passengers or the vehicle is transporting hazardous materials.
class D: Permits operation of any motor vehicle not included in Class A, B, C, or M.
class M Permits operation of a motorcycle.
/ How much? #24
In Georgia your ok as long as your combined truck and trailer is below 26,000#s. So if you have a 8000# truck pulling a 14000# trailer, your good. Over 26000#s you need a commercial license.
/ How much? #25
Isn't California more strict on trailers than any other state?
/ How much? #26
Ca. does have a farmers' exemption, but I'd have to check to see if an endorsement is required. Oregon has it too, but the limitation is on the commercial licensing of the "truck", not the driver. If the truck has personal plates, then there will be trouble towing anything over 10K. :mad:
/ How much? #27
Wisconsin
Positive. CA is the only state that reuires a special license because of a trailer being over 10k by itself. Every other state including WI reuires the combo to be over 26k CGVWR before the 10k trailer thing kicks in for CDL.
/ How much? #28
My neighbor was talking about getting a CDL and he said in California you had to use Cal tran approved staps for the loads.
/ How much? #29
This is the same for PA
Although, you better have your truck registered for combination weight if you plan to tow a trailer with a gvw of 10,001 or more.
/ How much? #30
First - based on the numbers here and to have a little buffer I would recommend at least a 12K unit. I have a CT235 and with several attachments, gear,fule, to go somewhere to do some work I am at just over 8K in weight. To make everything fit I measured and a 20+2 would work for me with either slide in or fold up ramp. PJ is a good brand too. I have learned the hard way that the extra capacity is worth the small costs. Loosing a bearing due to overloading one side in the middle of no where is not fun.
As for needing a CDL in Colorado, with the correct license, in this case a R, you can tow up to 26K combined vehicle ratings.
From Colorado DMV
Class R REGULAR; ANY VEHICLE WITH A GROSS VEHICLE WEIGHT OR GROSS COMBINATION WEIGHT RATING OF 26,000 POUNDS OR LESS, TRANSPORTING NO MORE THAN 15 PASSENGERS INCLUDING THE DRIVER AND TRANSPORTING NO HAZARDOUS MATERIALS IN QUANTITIES REQUIRING PLACARDING UNDER DEPARTMENT OF TRANSPORTATION (DOT) REGULATIONS.
Hope this helps
/ How much? #31
I have a CT450 backhoe loader. I Also have a 2500hd and a gooseneck trailer. Im in pa and I have a combination weight rating 22,000. It cost me $405.00 a year for registration. I figured better to pay 405 a year Rather then what the fines cost if i get pulled over.
Rhino RC20 (A64119)
Rhino RC20 (A64119)
2005 International 4400 S/A Day Cab Truck Tractor (A61573)
2005 International...
Topsoil Trommel (A57453)
Topsoil Trommel...
2006 FREIGHTLINER M2 106 T/A BOX TRUCK W/100 PSIG AIR PUMP (A59912)
2006 FREIGHTLINER...
2012 Ford F-350 Western Mule 1,500 LB Crane Service Truck (A61573)
2012 Ford F-350...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
