Any one Modified their brush guard
/ Any one Modified their brush guard #1
Chuck K.
Gold Member
Texas Gulf Coast
2009 M59 w/thumb
I knew it would happen one day and it did,, while stacking a brush pile with my grapple I ran a limb through the brush guard and into my radiator..The good news is the radiator is easy to remove, I JB welded the leaking tube and going back together with it this evening. I am looking for ideas on how to prevent this from happening again..
Thanks, Chuck.
On a side note those of you running HST system may want to look into loosening your Hydro. fluid cooler and throughly back flushing it.. I regularly was my machine but the amount of dirt and debri that came out when backflushing surprised me..
/ Any one Modified their brush guard #2
Weld some metal screen to the guard, thats what I am planning on doing if I can find the right stuff.
/ Any one Modified their brush guard #4
I haven't on one of our newer tractors, but I am beginning to think it might be a pretty good idea.
/ Any one Modified their brush guard #5
Thanks, Chuck.
There have been a few threads about doing this - here's one:
http://www.tractorbynet.com/forums/build-yourself/178946-jd-3032e-brush-guard-bucket.html
/ Any one Modified their brush guard #6
Since I don't weld, this is what I did. I went to Home Depot, Lowes and TSC and looked at their expanded metal. In all cases, I didn't think that the product was heavy duty. I called my dealer for advice and he referred me to a welding shop less than a mile from his dealership. I took off the guard on my L4400 and took it there. It costs me $40.00 - no tax. I don't recall the guage of the material, but it was 3/4 expanded metal and it was much thicker and sturdier than the material that I had previously looked at. If you choose to have this done, please be sure to weld a piece on the bottom section also. BTW, they also painted it - same price- but I supplied the two cans of Kubota paint. Best wishes.
/ Any one Modified their brush guard #7
Here's my B3200 with some expanded metal and an extra cross bar welded. Not sure how much it will affect the lights. Want to add some lights to the ROPS anyways
/ Any one Modified their brush guard #8
That looks nice, Now you have me thinking about my B2320. It lives in the woods for the most part.
/ Any one Modified their brush guard #9
Yep, and I did it for the same reason, but before the problem actually caused real damage. I also did expanded metal on the back of my grapple for the same reason. That helped the grapple work better too as having a backstop to push against meant things got scooped up better. You can see that in one of the pics too.
http://www.tractorbynet.com/forums/welding/219535-grill-guard.html
/ Any one Modified their brush guard #10
I had to do my grill guard a little differently, since the frame is hinged on my MX5100. But like the OP, I learned I needed one the hard way after I poked a hole in the plastic nose of the tractor. And like dstig, I added expanded metal to the back of my grapple after an unfortunate incident occurred while using it in heavy brush (chronicled elsewhere in these forums).
Jay
/ Any one Modified their brush guard #11
I also need to do this;wiped out a battery and the lower grill.Lucky not to get the radiator.Thought it was strange the tractor wouldn't start in August............
/ Any one Modified their brush guard #12
Yup...Been there, done that...
/ Any one Modified their brush guard #13
I've used #9 gauge expanded metal. It is very strong compared to what you will find at TSC, HD, Lowes, etc.
/ Any one Modified their brush guard #14
That expanded metal doesn't hold up as well as woven wire, trust me I know. I had my welder put on 3/8 inch. screen with 1/4 wire. I do screening of gravel and loam so I had the screen. You could go to an outfit that does this and ask them if they have any screen pieces laying around. The wire in these screens are hardened steel so it is strong and lasts.
David
Finally a picture.. got the idea looking at my brother in laws dozer..IMAG0206.jpg
/ Any one Modified their brush guard #17
I learn a lot on this forum. I was actually wondering how to address the possibility of a stick damaging my radiator, etc. Great info, thanks for all the pictures. I am pulling my welder out soon and modifying my guard.
/ Any one Modified their brush guard #18
Here a couple pics of the addition to my brush guard. It has already saved my judging by the large dent in it over the middle brace. My brush guard also hinges so I still need to add some to the lower fixed part. When I was done welding I decided there was to much orange up there so I gave it a few shots of flat black followed with shaker can clear.
/ Any one Modified their brush guard #19
good job guys ,thanks for sharing.
I will be doing this soon as yesterday morning a branch came thru the grill and was stopped by the battery(no cracks) looks like some heat gun reworking of the plastic part of the grill will repair it.
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 48in...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A62129)
2019 KOMATSU...
BUYERS PREMIUM & PAYMENT TERMS (A59908)
BUYERS PREMIUM &...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59909)
2020 VOLVO VNL760...
