Powershift grinding (always engaged?)
/ Powershift grinding (always engaged?) #1
Nazrat
I have a YM122 (like the YM146, but 1cyl) that I'm working to resurrect. It is running very well but the Powershift system seems off. From what I read I should be able to select a range between my legs, then use the column shift to go between R, N, 1 and 2 without using the clutch. When I try that the gears grind - so I don't try it :) If I use the clutch it shifts fine and has lots of power. I changed the transmission fluid (using the JD spec fluid). Where do I start? Is the mechanism that controls the shifts located inside the transmission? I haven't found anything on the linkage.
Thanks for the help.
Tad
/ Powershift grinding (always engaged?) #2
I am not familiar with that one but only 1-2 upshift can be done w/o clutch. From neutral into 1 or R could be done w/o clutch as long as main box is in a low low gear on what I am familiar with.
For instance- like taking off with a tiller or mower attached and need it spinning before moving the machine. Otherwise there will be a jolt rather than a grind so thats kind of confusing the title is anyway? My powershift trans has a noticeable whine in it as long as the clutch is out fwtw.
I can't go from 1-2 either if that helps any. I don't notice any particular whine or whurr, like I'd get with a hydraulic pump under load. The pump for the blade lift makes that noise when under load, as expected.
-Tad
/ Powershift grinding (always engaged?) #4
-Tad
Are you sure its a powershift?
I suppose that I don't. I assume based on the hydraulic transmission, as well as the info I found on the web (which is scarce).
Thanks,
Tad
That's great, I'll take a look. This is actually a YM122, but it looks like it's in the same category. YM122, YM146, YM12, etc.
-Tad
So based on that manual (for the YM12) this doesn't have powershift. From what I can see the transmissions are the same externally. The way to tell is to check for a filter screen. I'm going to assume that it doesn't have it and drive it as I should, with the clutch. For anyone who happens to see this while looking to buy my YM122 in the future, I only tried each gear once, and it still functions just as it did before.
-Tad
/ Powershift grinding (always engaged?) #9
looking at the manual the YM12 and 14 run the same transmission, it is powershift. mine makes no noises as such when shifting. you cannot move the range shifter on the fly, only the powershift-1-2-R and onward. low rpms are OK with no clutch, but higher rpm snaps it into gear so go easy on that. you need to stop, put it in neutral on P/S, move range lever to desired range and away you go using powershift on steering column. i am trying to find my manual on CD to email you with but have not located it yet.
Ok. Does your YM14 have any external indication that it is a powershift? How about in the path between the shifter and the transmission?
-Tad
/ Powershift grinding (always engaged?) #11
Nazrat.....Pictures would really help to confirm if you have Powershift or not
Sure, what would you like pictures of? Here is the shifter/sticker:
Here is the front of the transmission:
Here is the back of the transmission:
And here is the whole unit:
-Tad
/ Powershift grinding (always engaged?) #13
I am not familair with your model but I have read that is very simialir to the GT-14 which there are a few members who have them. I don't think that is a powershift though with just Forward, Nuetral and Reverse...but if you search on GT-14 I am sure you will find some owners who you can PM.
/ Powershift grinding (always engaged?) #14
DSC_0740.jpgit should have on the column, N-R which is down and 2 forward, 1 is the first notch and second is all the way forward. then you have 3 ranges I,II and III down to your right. that gives 3 reverse and 6 forward gears.mine also has powershft stickers on it.
/ Powershift grinding (always engaged?) #15
i did find something on a sliding mechanical trans in the manual, maybe it has that being the 1 cylinder?
On the column shift it does have 2-1-N-R, but according to the parts manual both the Powershift and the gear-shift have the same shift pattern up there.
I found three things of note in the parts manual:
1) The YM14 shows POWERSHIFT stickers and the YM12 does not.
2) The Powershift transmission has a plug on the right side case near the back on the top. Appears to angle back about 45*
3) The Powershift transmission has a shift cable, and the gear-shift transmission has a solid shift linkage.
I know I don't have the Powershift stickers, but tomorrow when I have time I'll look for the plug as well as look at the shift linkage.
Thanks again for the help.
-Tad
/ Powershift grinding (always engaged?) #17
-Tad
1) True
2) thats the trans filler plug
3)if thats the case it must have that sliding mechanical trans they talk about, i dont think the GT14 has that? i am sure they are powershift being the 2 cylinder.
Yanny Man has a few of them, but i havent seen him on here in a while.
I'm satisfied that this isn't a powershift. It has a mechanical linkage and it doesn't have the fill plug on the top corner of the transmission case.
Thanks all for the help.
-Tad
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2005 Volvo VHD Roll Off Truck, VIN # 4V5KC9GF75N395481 (A65563)
2005 Volvo VHD...
Coleman Go Cart (A65640)
Coleman Go Cart...
2025 Swict 84in. Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A64553)
2013 Volvo BL70B...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
