Small solar sysem for remote power
/ Small solar sysem for remote power #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I am starting to research solar electricity for my tower stand. I don't need a huge system, just something that can charge my phone, possibly my laptop and run a small fan. Do you guys have any suggestions or warnings? Thanks in advance.
/ Small solar sysem for remote power #2
I am not sure of your complete requirements. To charge a phone, a 12" square panel will charge in a couple of hours in bright sunlight. A laptop is a whole other story. Much higher power requirements. An efficient panel (top of the line) will generate about 15 watts/sq-ft. This is at noon on a perfectly clear day. So you can estimate the size you need vs. size.
paul
/ Small solar sysem for remote power #3
May I ask a question on this thread? I received an email from someone claiming to have plans for a solar panel that he built from things from the local hardware store for much less then commercial panels. I considered it to be BS Can a solar panel be built from items from a hardware store? I do not want to hijack the thread just think maybe this can help.
paul
I doubt I would ever take the laptop because I can do just about everything from my phone anyway. So if I could get a simple system to charge my cell when needed and to run a small fan (to help keep the windows clear and circulate the heat) then I would be happy.
Don't worry about hijacking this thread. It is always fun to see where threads lead :D
/ Small solar sysem for remote power #6
People are pretty loose with the usage of "solar panel". Maybe it was referring to a hot water or air panel. Those could be built from any decent hardware store.
/ Small solar sysem for remote power #7
With all the theft problems around, you might want a small portable one that you can hang on the tower when you are there, and take out when you leave at the end of the day. Nothing worse that having your stand stolen, and the panel with it. If in a "secure area, then a small battery with the panel, to store energy to run the fan, and still run your phone off from on cloudy days.
/ Small solar sysem for remote power #8
I would think about using natural circulation instead of a fan. A vent as high up as you can get it, and another one down low will give a strong natural air flow.
If you must have a fan, I have seen solar powered roof fans for a few hundred at Costco. Solar panel was maybe 14" x 14", possibly 16" x 16".
Solar cell phone chargers are commercially available. A quick look on Amazon finds prices between $25 and $140.
For a laptop, just buy an extra battery and turn down the screen brightness...
/ Small solar sysem for remote power #9
I was looking into this two years ago, but never followed through. I found that you get what you pay for in solar panels. Same thing with a deep cell battery. My plan was to mount the panel to a car battery and wire a panel of cigarette lighters. I was thinking three sockets. One for my phone charger, and the other for a 12v coffee pot with one more open. I figured that if the solar panel charged up and kept the battery charged when I wasn't in there, I could draw down the battery when I was in there.
In the end, I bought a better phone that didn't go dead on my after an hour or two, and got a good thermos with enough coffee to last me the morning.
Too cold for a fan, but I do have two indoor rated propane heaters. Most of the time, one is plenty, but on those really cold mornings, I'll have both of them going!!!!
Did you find a comfortable seat? The one that I like the best is a folding, patio seat from Walmart with a cushion on it. I tried seat after seat everywhere I went and really liked that one!!!
If you're gonna build it, you might as well be comfortable in there!!!!
Eddie
Eddie
I use a leather office chair for a seat. Its great for getting the proper shooting position.
The fan is to help keep the main windows fog free.
/ Small solar sysem for remote power #11
This depends on a lot of factors. You may want to look into a deep discharge 12v battery. Either leave a battery and a small solar panel at your location, so that the small panel keeps the battery charged for you or have your battery charging before you go hunting. This would mean carrying a battery which could be heavy. Depends on how much power you need and for how long.
Keith
/ Small solar sysem for remote power #12
There are solar water heating panels which can be built from hardware store parts. A simple one is basically just pipe / plumbing parts pieced together to get the water to sit out in the sun and heat up. These were popular before electric solar panels became popular. You can also buy solar cells on ebay and build your own enclosure for the solar cells. Maybe they were talking about that. I guess if you really wanted to rig something up, you could buy a bunch of those solar yard lights at the hardware store and wire them all together to charge a big battery? Technically it's possible and they are available at the hardware store. So, sure. It could be done, not very practical.
I'm guessing they were talking about solar water heating though. If you don't have to worry about stuff freezing, these can be really simple.
Keith
Keith
I have thought of using a marine battery for this application and may go this route with a small solar charger. How well would a battery hold up to this application? Basically only getting used 1 month out of the year. Of course if I size it right I can always steal it if one of the batteries die in a tractor.
The circulation issue is why I want a small fan. The tower is built solid and sealed up and insulated on all six sides so that it heats easily. The problem is that there is moisture in the air inside from the fact it isn't heated 24/7 so when I turn the heat on the windows fog up and start condensing making it hard to see out of them without constantly wiping them off. So I would like a small fan to just aim at the windows like the old trucks and busses use to have. Just something in the six inch size.
I've found small battery operated fans but I fear how long the d batteries will last in 0-30°f weather as the heater is only on while I'm in there.
I don't worry about theft too much. The tower has a deadbolt so someone would have to really come prepared to break in.
If I go the battery route it will be stored in a battery box inside the tower so its secured.
Here is my tower so you guys know what I'm talking about.
/ Small solar sysem for remote power #17
And I just settle for a stump and not a flat one :confused3:
I always wanted to build a few tower stands like this but what actually pushed me to start was when I broke my back. I do not do well sitting on stumps, standing for long periods of time or being cold. So in order to be able to continue to hunt I was going to need something better that would allow me to move as needed so that I don't start hurting. What I didn't forsee when I started thinking about building the tower was that it would make it easier for my daughter to go with me. She goes almost every day with me during hunting season (as long as she doesn't have school) and loves it. I have a recliner in there that she sits in and colors, plays her Nintendo DSi, looks through the binocs scanning for deer and just keeps me entertained. Oh yeah, she also eats all my food and drinks all my drinks. She loves hunting and it has been a blessing having the tower. So now I am finishing up this one and when finished I will start the next one. The tower is 7.5' off the ground, just enough to see the entire field and is 8x8 outside dimension which allows plenty of room for Avas recliner and my office chair, the propane fueled Mr. Heater on the wall and a 5 gallon bucket that is the tower toilet.
/ Small solar sysem for remote power #19
I vote for a car/marine battery, a solar panel, and an inverter. Good to go. Get a battery that would work with your tractors and now you have a spare if needed. I think you are set.
/ Small solar sysem for remote power #20
Robert, I am thinking the propane-fueled Mr Heater is the source of a lot of the moisture. Plus two people in a small, well-sealed room. You may need to bring air into, and exhaust air out of the tower to really improve the moisture condensation. You have to figure the glass in the windows is often below the dew point of the interior air.
Curly Dave's suggestion of a solar attic fan may be what you need.
