Naive...but
/ Naive...but #1
Danbo56
Member
maryland
MF-50
I have 2 ~6 ac pastures that i mow with my bush hog. They are for the most part square. I'm mowing in decreasing size squares. I'm making alot of clover leaf circles on the corners. Is there a more efficient pattern to mow?
:confused3:
tanks!
/ Naive...but #2
I do the same thing when I start at the edges and mow to the center. If you tried the opposite and start in the center and mow to the edges you will not have that problem. You will have some corners to clean up after you get the majority done though. The trick is to start as dead center of the field as you can get. Try it next time, you might like it better that way.
/ Naive...but #4
i mow my perimiter, then make a pass down the middle.. then I walk that pass so that I cut the outside of one rectangel, and the inside of the other rectange. both rectangles disappear at the same rate and I am driving the same distance of circuit.
/ Naive...but #5
Make a quick circle out on the corners will stop the looping. After you get it down to a acre or so, lay that off in a "Land" to finish. Ken Sweet
/ Naive...but #6
I do it like Soundguy said, but I do the perimeter last. Nothing to do with efficiency -- I hate killing praying mantises. If I cut towards the center, they'll get trapped. Those girls do such a good job on the bugs around here, that I don't feel foolish making a little extra effort to be sure they can escape into the woods.
/ Naive...but #7
Mow a few laps around the outside to get some room to move, then one strip down the middle. You now have two rectangles, like Soundguy said, and you can take a strip off each of them with every pass with very few actual stops and turns. I call it a "Zamboni pattern", if you've ever seen an ice rink resurfaced.
Sean
/ Naive...but #8
Like the others, I mow four or five passes on the ends then mow a strip down the middle to define two rectangles. Then you just mow an edge off of each rectangle until the two rectangles are consumed. That way you don't have to mow the entire end pass each time, just half. It is amusing to get to the last few passes to see if you estimated that down the middle pass just right so it all comes out evenly.
The turns are made on already mowed ground so there are no crescent moons of missed grass.
If you have a really large field it can be partitioned into several rectangles to be cut two at a time.
When I disc I do exactly the same thing.
Wish farmwithjunk was here to explain how he does it.
/ Naive...but #9
Ok. 4 or 5 of you have described this 2 rectangle thing, and I don't have a clue what you are talking about. I am sure this works, or so many of you would not be doing it, but I cannot visualize it at all.. I understand the mowing around the perimeter, part and then the mowing a pass down the middle and your are left with 2 rectangles. Then what do you do.? None of the other phrases made any sense to me. And it would seem to me you would be traveling over an ever increasing amount of already cut grass and wasting both time and fuel. I am not doubting what ever you are doing is working, but I cannot see it.. Could one of you please draw a few diagrams of the pattern starting after the 2 rectangles are formed. Thanks
James K0UA
/ Naive...but #11
Ok I believe I have it now... thanks
James K0UA
/ Naive...but #12
James,
Thanks for raising the question. I was similarly confused. And Steve, thanks for the link. It was just what I needed. Now if I had a field and a tractor, I could practice. :)
--LogChain
/ Naive...but #13
The Canadian in me was going to say the same thing, just like a Zamboni cleaning the ice!
/ Naive...but #14
James K0UA
yep.. you are actually keeping the same distance.. not an increasing distance.. you are just 'walking' the cutting area.. as said.. when yuo get down to the end you get to see if you guessed middle correctly.
/ Naive...but #15
Not being Canadian, I was missing out on the Zamboni connection:) But I got it figured out now.. thanks all.
James K0UA
/ Naive...but #16
I guess I just do it like the OP first described. Yea, its a PITA, but nothing around me is square. Everything is odd shaped, triangles, ells, etc.
And since I cant drive a straight line:rolleyes:, i'm no good at the zamboni pattern. Cause I usually end up with a LOOONG slender triangle shape that is maybe 30' wide at one end of the field, tapering to nothing 500' away at the other end. And cleaning those up isnt very efficient. Ends up taking more time than just making tight turns on the corners, or cloverleafing. If it is just a darn field, left and right braking helps speed the turning up too:thumbsup:
Ideally, a field would be perfectally round and you can just spiral in or out and NEVER have the cutter out of the work. But I think I would get dizzy:confused2:
/ Naive...but #17
Every time you get to the end of the rectangle, you drive over an already-mowed area. The wider the rectangle, the more time it takes to start the next strip of actual mowing, so dividing the field into several narrow rectangles is somewhat more efficient. But you have to accurately eyeball a parallel "plunge cut" for more rectangles, and cleaning up when you make a mistake can offset the time you gain. :wink: If you get good at it, it's about as fast as using the turning brakes to make square 90 deg or 180 deg turns when mowing.
/ Naive...but #18
Does everyone lift the cutter when making sharp turns (assuming you have a lift type) or do you just sling it around on the tail wheel?
/ Naive...but #19
Part of the trouble with square mowing patterns is that towards the end of it, you're making almost nothing but turns, since the legs are so short. Once you have the rectangles established, I try to cut mostly on the long edges to prevent that. I'd sooner drive a few more feet ahead unloaded to get to a long steady cut than spend more time stopping and turning, or doing cloverleafs.
Sean
/ Naive...but #20
On smooth ground I leave the tail wheel down, but since there's not much smooth about my fields I usually lift it.
Sean
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
FIRMAN H07553 GENERATOR (A64276)
FIRMAN H07553...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
211298 (A62131)
211298 (A62131)
