Jeep Wrangler
/ Jeep Wrangler #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I always thought a Jeep with a snow blade would be the best vehicle for moving snow because of its ability to manuver in tight quarters. But all I ever see are pick-ups, and some of them get pretty long, like the one tons with 4 doors and an 8 foot box!
Is it simply a matter of using what you have or are the Jeeps just not strong enough to handle the abuse?
/ Jeep Wrangler #2
Big tiller, years ago when I was going to college I used a Jeep CJ with a plow to plow snow in Northern Illinois...we did parking lots and driveways....commercial stuff..the jeeps worked fine and I even had a 2 wheel drive International Harvester ( like todays SUV ) with chains and a plow that also did great...we had many 12 " plus snow falls...
/ Jeep Wrangler #4
I have plowed with both jeeps and trucks. The jeep does great for tight quarters and such. Never had a problem with damage to it.
One thing to keep in mind as to why you see the pick-ups is that they use the truck for other things in the off-season and in the winter you can outfit them with salt spreaders.
/ Jeep Wrangler #5
I run a 95 YJ Wrangler.. Last year of the leaf spring front end jeeps. 4.0 liter, 5 speed, with a Blizzard 760 speedwing... it is alot more plow than most will run on anything less than a half ton truck.. The plow contains alot of snow since the wings default in the scoop position.. I will put my Jeep against any truck with an 8 ' plow anyday of the week and guarantee it will out plow it. Maneuverability is 2nd to none on it ! I do run about #600 ballast in the back of it, because it will come light on weight pushing heavy or deep snow.Maybe I can find a picture or 2 of it
/ Jeep Wrangler #6
Picks of the jeep with the 760 speedwing 7'6" in scoop 8' with the wings pinned back in the straight position.
/ Jeep Wrangler #7
Here ya go - the best of both worlds....
Decision on a Jeep pickup coming soon, truck could come on Wrangler or Fiat platform
I always plowed with a Dodge Power Wagon called a SNO FITER...not a typo that's what they called it. That thing plowed like a tank, i had a stick shift and I never could kill that thing. I plowed some times 24 hr a day, only taking naps with my head on the steering wheel in the middle of a large parking lot in the middle of a storm . You had to make it while it snowed.
Here's picture of what she looked like same color and all.
http://www.cardomain.com/ride/3841958/1974-dodge-power-wagon
I was only 18 when my parents signed for a new truck and plow. Then came Nov. Dec. and not a snow flake in sight. They were great, they never gave me the " I told you so" look.
The first snow fall lasted a week. At the end of the week i dumped enough cash out of every pocked from my pants and jacket enough to pay for the truck 100%.
I like the pick up because I could load the back with bags of rock salt for weight, plus I gave it away to my customers.
I drove that beast hard and never spent a dime on repairs. They don't make em like that any more.
/ Jeep Wrangler
Do you think maneuverability trumps the lack of weight? I would not like to add and remove 600 pounds of ballast by hand everytime I needed to move snow.
/ Jeep Wrangler #9
Do you think maneuverability trumps the lack of weight? I would not like to add and remove 600 pounds of ballast by hand every time I needed to move snow.
No. I am running a plow that's alot bigger than the jeep should be carrying, If you went with a 6 1/2 ' blade you would not need that much ballast. I don't have any family so Losing the back seat isn't an issue for me anyway.. Plus its not my only plow truck.. I do have full sized trucks as well..
/ Jeep Wrangler #10
Best plow vechicle I owned was a 1976 CJ5 with a 6 1/2 ft meyers power angle blade and a 3 speed trans. Very manuverable and so simple to shift foward and back with shifter. I had 5 plow vechicles at the time 2 CJ5's 1 full size blazer 1 International scout and a3/4 ton dodge power wagon. did a lot of commercial lots and residental drive too. All of my drivers wanted my CJ5 with the 3 speed!!!!!!!! JUST SAYIN'
/ Jeep Wrangler #11
Cat that is the same Powerwagon I plowed with only automatic trans. You are right couldn't stick that thing just keep on truckin!!! (not so good for small drives though!)
/ Jeep Wrangler #12
[The first snow fall lasted a week. At the end of the week i dumped enough cash out of every pocked from my pants and jacket enough to pay for the truck 100%.
You plowed for a week straight and had enough money to pay for a new plow truck.
You must never get tired.
The truck must have been dirt cheap.
Having not been in the plowing business where did you find all the accounts ?
If the story is true it belongs in the Gunisses book of records.
Well done.
/ Jeep Wrangler #13
If I were doing my driveway and needed manuverability the jeep would be great. But running commercial accounts and needing to move ALOT of snow, by far the best rig I have owned/used is my 01 F250 Diesel ext cab short box. It has the right amount of manuverability, can push a bunch of snow with a 9'4" v plow and is almost 10,000lbs ballasted out for plowing. So like anything else it all depends on WHAT you are doing. CJ
/ Jeep Wrangler #14
Well done.
+1 I could have made more working at mcdonalds!! It was a good tax writeoff and the real money came with the large equipment for pushing banks back and large parkinglots. One of the worst trucks I plowed with was a 1/2ton dodge. Between rusting trans pans and weak front drivelines and steering parts falling off. I was 1 of the lucky ones, no trans failures. My buddie put in 6 under warranty before it went off and sold the truck. CJ
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
Caterpillar D4D Tractor Service Manuals (A63117)
Caterpillar D4D...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
John Deere 1023E (A62177)
John Deere 1023E...
Cat CB24B (A60462)
Cat CB24B (A60462)
RoGator and Terragator Manuals (A63117)
RoGator and...
