Attic insulation question...
/ Attic insulation question... #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I'm working in Florida right now so I'm simply working as a middleman between my wife & keyboard...
Scenario: Seems my sister in law did some changes in her house (her brother who lives out of state did the work when he was living in the area)
House built perhaps in the 60's (just guessing)
In the kitchen, they removed all the ceiling drywall. I don't know what was above the drywall but from what I understand they then raised the ceiling level and essentially put new drywall on the roof itself, as in, mounted the drywall to the underside of the roof. (I asked for pictures becuase I'm sitting here wondering what happened to the horizontal joists that might have been in the ceiling)
I don't even know if that part is important to the question.
Seems they took pink insulation, mounted it directly to the underside of the plywood that makes the roof. They then mounted the drywall on the other side of the insulation.
Seems there is no venting space in there and now she's had some condensation form and a portion (all?) of her drywall needs to be replaced on her ceiling.
It's possible that it's a leak for all I know.
I asked her if someone could take a picture of the ceiling and perhaps... a before picture and/or a picture with some drywall removed (if they exist) to at least put some visuals into the conversation. No luck so far.
So the upshot is, if you have your roofing plywood with insulation butted up agasint it and your drywall butted up against the insulation, is it reasonable that you've created a problem and if so, would they have been better off using something like a foam-board / hard insulation instead of the pink Owens Corning style?
Given how the wife described it, I'm presuming to fix it right, the ceiling will have to be pulled down, reinsulate and reinstall new drywall.
Thoughts given the minimal details?
/ Attic insulation question... #2
You are discribing a cathedral ceiling which is the hardest roof to vent! No matter how you look at it there MUST be a space between the insulation and the underside of the roof deck, proper soffit and ridge vent. Personally i would go to CertainTeed and see what they have to say. call their toll free number and talk to their reps. There good to work with, were one of their distributors. good luck . . . John
/ Attic insulation question... #4
you are guessing exactly as much we are. as you surmised- you really need to have airflow on that roof.
/ Attic insulation question... #5
J
Yes, a 2" air gap, vented top and bottom would be the minimum. IMO
/ Attic insulation question... #6
Without proper venting you can rot your house down, grow mushrooms on your rafters, mold, fungus ect. This is not a fix in a couple of years thing. Fix it soon. By the way, I have been in houses that have had all of those problems. A cathedral ceiling is framed down from the rafters on a lower pitch, not hooked to them.
/ Attic insulation question... #7
I have a new home with icenene insulation (spray on foam). The underside of the roofing decking was sprayed with the foam directly known as "hot roofing". I investigated it some before allowing it to happen but it turned out to be an acceptable method with that insulation type. No air flow whatsoever.
/ Attic insulation question... #8
The foam is also the vapor barrier as I understand it. Including attics in "conditioned space" is becoming more popular. Since the foam seals the underside of the roof sheathing, it seems like condensation at that surface would not be a problem.
/ Attic insulation question... #9
They make styrofoam vent shoots, that you staple to the plywood before installing insulation. You may want to lower ceiling some to allow more insulaton. Spray foam is an option, but may effect airflow for the rest of the house and will shorten shingle life on that section of the roof.
Dave
/ Attic insulation question... #10
Rich, Three possible issues here.
1-roof leaks causing the water spot.
2- No baffles were used prior to insulation, Fiberglass does not create enough of a vapor/air barrier to use without proper ventilation. Done right there should be vented soffits, continuous baffles to the ridge and an adequate ridge vent. If you don't do this you will have mold problems. Doing this method significantly reduces the insulating value of your envelope. I am guessing that the rafters are 2x8 from the age of the house (could be different), if they are with baffles that leaves only 5 1/2" of space for insulation. With fiberglass the max you can put in there is R-21. I don't what the minimum R-value is for your area but this may not be enough, not even close for our climate in NY.
3-Collar ties/ceiling joist removed. This is a structural issue, they not only are used to attach the ceiling to, but provide structural stability to the roof system. They counter act the forces applied to the outer walls, preventing them from bowing out. Removing them is just asking for trouble down the road.
Solutions-
1- have roof inspected/fixed
2- Pull ceilings and insulation. Have closed cell foam sprayed full depth between rafters. This will provide excellent R-value and a very good air/vapor seal. Just make sure it is closed cell and not open cell. Then you can attach new ceiling.
3- Install collar ties no higher than 1/3 the vertical height of the rafters creating a raised flat ceiling, or tear off the whole system and install scissor trusses for the cathedral effect.
Good luck.
/ Attic insulation question... #11
styrofoam vent shoots, we have them in our attic, can you spray foam over them or should they be removed? we were thinking about getting the roof sprayed eventually (a-frame roof 10/12 pitch)
/ Attic insulation question... #12
Since adhesion to something is critical to resist the weight of the insulation I would say the vent shoots would need to come off.
/ Attic insulation question... #13
Forge, if using spray foam pull the baffles out and spray directly to sheathing.
/ Attic insulation question... #14
I'm thinking of insulating my ceiling with spray in foam too. I have 2X10 rafters and a vaulted ceiling. The ceiling sheetrock will mount to the 2X10s directly.
With the sprayed in foam that adheres to the underside of the roof sheathing, what happens if the roof leaks? Seems it would go unnoticed and rot the roof deck.
/ Attic insulation question... #15
Yes, that's a downside to spray on foam.
You must periodically inspect your roof and any sidewall transitions to be sure everything's still servicable. And correct any probs immediately.
/ Attic insulation question... #16
Ty sorry for the question mid forum appreciate the info though.
/ Attic insulation question... #17
One possible solution would be to add a new layer to the roof that created a space between the old roof and the underside of the new roof. Not an inexpensive solution, but would add appreciably to the ability of the roof keeping everything cool below (I've read that creating a space for airflow underneath the roof deck is equivalent to having a tree shading your house during the summer. Personally I would only consider going this route if the roof was already in need of reroofing, but not having to rip the interior ceiling out could be considered an advantage as well in factoring the cost as well as the energy savings over time.
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63118)
2012 Ford F-150...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
