Rear pull snowblower
/ Rear pull snowblower #1
LindyT
Hello guys,
I recently purchased a 2005 L4330HSTC - loving it so far. Had 700 hours, but well kept and maintained and will of course continue to be so. :)
I bought the machine for rotary cutting 10 acres behind our home. I also bought it for plowing our driveway and the area around our 62x100 building -- all of which is paved.
My initial thought was attaching a plow on the FEL, but with heavy Michigan snowfall, you run out of room for the snow -- plus, the plow is just obnoxious to maneuver around the circle drive, etc without damaging the lawn. I'm exploring blower possibilities. I'd prefer to keep the bucket and FEL to manage drifts, firewood, etc. The idea of blowing all that backwards isn't appealing to me, so I believe I'm settled on a rear pull-type blower such as the Erskine.
The question is, are there any reasonably priced alternatives to the Erskine? I can't see paying $7-8k for a snowblower for non-commercial use. I've come across the meteor unit, but haven't found much information about them.
Any insight would be appreciated and any thoughts on the rear pull from people who have used them in Michigan (or equiv.) winters would also be welcome. Naturally, one should expect to stay on top of snowfall - which with a heated cab, I don't think I'll mind doing -- a good escape from the wife and kids. :)
Thanks in advance!
/ Rear pull snowblower #2
I allways thought the pull style snowblower/thrower was goofy. If the snow is deep how is driving into it going to do anything? Now the tractor is stuck or just can't go through the snow, blower becomes obsolete, just my opinion. I bought a brand new blower last year for just over 1200 3pt style but I have to go backwards. I found it's not all that big a deal and I don't have to worry about getting stuck. I still have the FEL if needed.
/ Rear pull snowblower #3
LindyT said:
Hello guys,
Thanks in advance!
Meteor are good solid build snowblowers. Have not personally used one but have seen them used by co-workers and they like them.
Here is a video of one in action in some fairly deep snow
http://www.youtube.com/watch?v=t5dYUP7NInA&feature=youtube_gdata_player
If you notice they are usually mounted to bigger tractors (probably for ground clearance issues)
Another nice thing with this type blower is that you can use as a box blade to pull snow away from buildings and cars then engage to blow the snow
/ Rear pull snowblower #4
I own one of these units here in northern Michigan. It's mounted on a JD 3520 and I've had no trouble with snow depths. It also handles wet snow well. In summary I am really pleased.
/ Rear pull snowblower #5
What make do you own?
/ Rear pull snowblower #6
I've got a Lucknow 90" rear Pull that last year I ran on a JD5425 - Worked Awesome. I have a long Driveway and lots of space to clear, It's like your using a Zamboni when you look back and see your beautiful flat driveway with no tire marks.
I just got a JD4520 and will try it on that, it might slow down somewhat in the big stuff, but I never got close to getting stuck on the 5425. I also got a HLA 3600 84" Vplow Quick Tatch for the loader so if it's really deep I'll just put the plow down and clear a path while the blower cleans up everything behind me.
/ Rear pull snowblower #7
Have you looked into a Kubota front mount (drive forward) blower?
You will need a mid-pto to go with it, but driving forward is always easier.
Then put a rear blade on and you are a snow warrior.
/ Rear pull snowblower #8
With the amount of curves you've got there, the pull behind would be ideal. They are spendy though.
/ Rear pull snowblower #9
+1 on this. I have a similar layout with a drive-thru loop and long driveway. The pull-type greatly reduces having to look backwards. Although we get a lot of snow in my location it seems to never to dump more than 12" at a time (over the 9 years I've been here). My DK35 SE with the Meteor 75" pull-type easily handles it. Until last winter I used a smaller tractor and rear blade which required a lot of work in reverse. It was so hard on my old back that I had to quit plowing one neighbour's driveway. Thanks to the pull-type blower I'm again able to clear the large dumps from her driveway(another neighbour does the small ones with a quad) with no discomfort. I think the time I spend clearing has easily been cut to 1/3 what it used to be, and with NO back strain.
ERichter posted a link to a good video. Here is another one my dealer made for YouTube:
Snow Removal.mp4 - YouTube
As long as your tractor can get through the largest expected single snowfall a pull-type will likely serve you better (in my opinion) than a standard rear-mounted blower. The front mounted blower recommended by RFB will also serve you well but will be more expensive.
/ Rear pull snowblower #10
You could get a regular blower and convert it to a pull type yourself.
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
LaneShark L53 (A60463)
