300CX Loader Joystick
/ 300CX Loader Joystick #1
pane056
Lake City, Michigan
CaseIH 685 & JD 3320
Hello;
We took delivery on a new 3320 Cab Unit with 300 CX loader. WE traded in a 3320 open station with 300 CX loader.
The joy stick on the new unit is almost impossible to move. Some times both hands are required. The original 3320 operated effortlessly.
Is the new unit operation normal or is it in need of adjustment or something else?
thanks, nicholas
/ 300CX Loader Joystick #2
Sounds like you have the joy stick lock engaged or partially engaged. Have you checked that?
/ 300CX Loader Joystick #3
Congrats on the new equipment. Either your joy stick lock is engaged or the motion needs to be adjusted. Pull out one notch on the lock and see if it makes any difference. When I got my 3720 the joy stick was stiff but not hard to move.
Hello;
I is dumb, I is dumb.
What joystick lock. Didn't know it had one. On the front left corner near the floor on the joystick counsel is a small, black,steel gizzmo in a small pocket keeping it almost out of sight. What is that? It flops around loose but won't come out of the pocket.
Are the joysticks on a cab unit considerably stiffer then on a unit without a cab?
thanks, nicholas
/ 300CX Loader Joystick #5
My joystick was a little tight when it was new. It loosened up after just a few hours of work.
/ 300CX Loader Joystick #6
pane056 said:
Hello;
thanks, nicholas
I don't know on your model but it just should slide or pull out (not all the way). Mine was half way between engaged and disengaged and it was sticking in between. On the 2520 it just slides in the way of the linkage so it can't move.
/ 300CX Loader Joystick #7
Locate your Operators Manual. If you don't have the manual go here: OMLVU19809_L8
Scroll down the left side and look for "Operator Station Controls (EHydro With Cab) go to that location. The lock lever is located at (e) on the bottom of your joy stick according to the JD pictorial photos.There should also be a label affixed near the lock lever with two locks, one locked and one unlocked. Move several times from the locked to unlocked position, leaving in the unlocked position. When placed in the locked position it prevents the joy stick from being moved.
A - Operator Seat Weight Adjustment Knob
B - Operator Seat Adjustment Lever
C - Differential Lock Pedal
D - Rockshaft Rate-of-Drop Control Knob
E - Dual Selective Control Valve (SCV) Lock Lever
/ 300CX Loader Joystick #8
Everything is normal with your tractor. I know exactly what your talking about. Your old tractors joystick connected directly into the valve body. Your cab tractor does not go directly into the valves. You have long length cables that twist and turn a couple times before they get to the valve body. It's not direct like your open station. This creates a considerable amount of resistance in the side to side motion most noteably. Would be nice to have electronic over haudraulic controls like most of the new equipment that crosses my jobs but who knows. Maybe it raises the costs too much.
Hello;
To all of you, Thanks Very Much.
I did locate the joystick lock. Does not seem like it does anything. Just flops around loose.
Thank you, nicholas
/ 300CX Loader Joystick #10
New tractor-why are you fooling with it-dealer should have his butt at your place.
/ 300CX Loader Joystick #11
Hello;
Thank you, nicholas
I agree with Red Horse. The joystick lock should not just "Flop Around Loose". I think it is time to wake up the dealer. He has been asleep to long.
/ 300CX Loader Joystick #12
i tried to explain to the guy so i hope he read my post. his condition is normal and can seem very drastic going from the open station to the cab model. The joystick is loose and does flop noticeably do to the way the whole thing is engineered. The cab models have long cables and is not direct into the valves. Every single cab tractor in the 3000 series has this condition. Even all the new ones in the lots. I even checked 2 others on the lots. The dealer cannot do anything about this. is the nature of the beast. Through time he will get used to it. The joystick lock snaps in and out. The flop he is referring to is the joystick i beleive
/ 300CX Loader Joystick #13
here is some video i took so that maybe it can shed some light on the matter. in the video, you will see the joystick flop with the joystick lock engaged and disengaged. you will also see the effort it takes to move the joystick and last, you will see the long stretch of joystick cables that wrap around from the cab to the rear of tractor this causes resistance you feel compared to your direct control open station joystick. hope this helps
joystick control - YouTube
/ 300CX Loader Joystick #14
Thanks for posting this video. However I have to respectfully disagree with you that this is a condition on all 3000 series. I have a 3720 cab that I purchased new a few months ago and the joystick is rock solid without any play. It came that way from the factory. This would lead me to believe, though I have not opened the console to look at it, that there is a way to adjust and firm up the joystick to take out all the play you show in your video.
/ 300CX Loader Joystick #15
I haven't had the opportunity to open up that console to see if I can take up slack. The other unit on the lot had same condition. Would be nice! I also had to adjust my 3pt lever cables. It wasn't raising fully and was hitting console
/ 300CX Loader Joystick #16
My two cents-my 07 4720 cab is rock solid when the lock is engaged. Now the 07's did not have the button for the third valve so perhaps that is the difference. Also, when you do lock it, even though the stick flops around are the loader controls in fact locked?? If so, that is the objective. In any case, I much prefer the lock mechanism on my cab 4720 vs the cheesy lever that was on my 05 3320 open station.
/ 300CX Loader Joystick #17
the bend radius on the cables looks to be a little tight outside the cab. from your video. that will make them extremely stiff to move. the neutral slop seems excessive too.
/ 300CX Loader Joystick #18
most definately sir. Like the other fella mentioned, i may take the panels off and attempt to take up some slack if possible. The other guy stated his machine doesnt have slack and he has a 2012 model like mine so there must be slack to be taken up somewhere. Maybe as simple as taken the wheel off and doing it right at the spot on the end of the video
/ 300CX Loader Joystick #19
Did you ever figure out a way to take up the slack and tighten up the joystick control? Mine has a lot of loose play before it engages as well - 2012 3520. Also, figure anything out on the 3 position lock? Mine does nothing!
/ 300CX Loader Joystick #20
I took my panels off and also the wheel so I had full access to the cables. There is obsolete lay no way to take up slack. The slop is in the stock cables themselves. If you adjust the connections at the ends, it doesn't take up slack but only moves the joystick off center. The joystick lock is a joke. I did center the joystick by adjusting the cables and got the lock to engage but it still sucks
2019 TerraGator 7300 Spinner truck (A63118)
2019 TerraGator...
2011 KUBOTA KX91-3 SERIES 2 EXCAVATOR (A64279)
2011 KUBOTA KX91-3...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
