Vent the heat? Louvers?
/ Vent the heat? Louvers? #1
nj82tj
Member
Holland, NY
2013 Kioti CK30
After a few hours of work today I shut off my NAA I noticed quite a bit of vapor venting from the gas cap. I opened it slowly to find that the gas was boiling in the tank...I let it cool obviously then started thinking about how to keep the gas cooler since it sits on top of the motor on my old Ford. I want to put some heat shielding on it to deflect some heat, but I'm curious if anyone has put louvers in their hoods to vent the heat? My temp gauge shows normal temp range during operation so I'm not VERY alarmed but would like some opinions or ideas on this. Thanks!
/ Vent the heat? Louvers? #2
If you are talking about venting the top of the hood with louvers, that will most likely transfer more heat to the tank. A heat shield is a better approach. Just a thin piece of sheet metal between the tank and the top of the engine and exhaust manifold with about one inch of space between the the tank and the sheet is all you'll need
Thank you for the advice! While I'm not sure I understand how venting the hood could make the tank hotter, my first approach is going to be the heat shield. It will be easier too, I think.
/ Vent the heat? Louvers? #4
With the engine off you'll have more warm air rising around the fuel tank with louvers than without so you'll have more convective heat transfer. . You could put forward facing louvers on the top of sheet metal but tractors don't move fast enough to generate enough dynamic pressure to force a significant ammount of flow though them and the place you need the cooling is at the bottom of the tank.
Louvers are generally used as vents where cooler air enters an engine compartment, cools the contents then flows through the louvers to exit the compartment. They are also more generally used on vehicles that travel much faster than a tractor.
I believe the 600-800 series Fords had tank heat shields on them.
Thanks Jerry/MT. I'm going to put a shield on it.
/ Vent the heat? Louvers? #7
You might also try putting on some of the reflective backed insulation around and below the tank if possible.
/ Vent the heat? Louvers? #8
does it have the OEm heat shields on it.. especially the one ove rthe muffler ???
take pics if you don't know...
There is one above the muffler. I don't see any between motor and gas tank though. I'm going to try some self adhesive shield there.
/ Vent the heat? Louvers? #10
not much heat comes off the valve cover.. it's a mostly empty cavity with a valve train above the head.
the muffler itself is the big source
/ Vent the heat? Louvers? #11
Is the engine fan working? The engine fan should be moving enough air to displace engine heat. Did the fan have a shroud? If yes, was the shroud removed? Boiling gas would excite me. I have only witnessed one liquid vapor explosion in my lifetime, happy to say I witnessed from some distance away and was told after the fact it was a liquid vapor explosion.
Watch the woman keep trying to look over the fence: BLEVE - Acronym for Boiling Liquid Expanding Vapour Explosion - YouTube (This is not the explosion I witnessed)
/ Vent the heat? Louvers? #12
Double post -Removed
/ Vent the heat? Louvers? #13
with ethanol in gas today.. i don't doubt there is some boiling...
There was rapid release of a gas from the gasoline inside of the tank. If it wasn't boiling I don't know what to think.
The fan dose work but I'm not sure about the shroud. I'm still going to put in a heat shield but I'll also look into the shroud. Thanks for the bleve lesson. I did not know about that.
/ Vent the heat? Louvers? #15
i'm sure if you hear boiling that it is boiling. this new gas is junk.. :)
/ Vent the heat? Louvers? #16
How about finding some methanol free gas? Some gas stations are carrying it for recreation vehicles. It might improve tractor/engine performance.
/ Vent the heat? Louvers? #17
maybee ethanol free.. :)
I was looking at it a few mins ago and thought about heat wrap. I might try to wrap the muffler. I think that would greatly reduce the level of radiant heat coming off the muffler. Also, the fan does work fine and there is a shroud around it.
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
(1) 8 LUG TRAILER STRAIGHT AXLE (A64280)
(1) 8 LUG TRAILER...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
42" X 21' ADS DRAINAGE PIPE (A64281)
42" X 21' ADS...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2022 Chevrolet Tahoe SUV (A61574)
2022 Chevrolet...
