Front recovery points...
/ Front recovery points... #1
Buckgnarly
West topsham VT
Kioti DS3510
Always like to be prepared, and don't want to use the bucket hooks as such, so I made this plate for future use...
/ Front recovery points... #2
Nice, I may have to steal your idea, if you dont mind
/ Front recovery points... #4
Nice - looks strong and well made. Always easier to have a pull point ready made than to wish you had one if the tractor is in mud up tp the engine. If your going to have to pull the tractor its always nice I guess not to damage it while you pull it! Tractor on.
/ Front recovery points... #5
I like that. So how much can you pull with these tractors? I have heard people telling me not to pull out tree's with a tractor. lol Not that I was planning on it...
I would not do any serious pulling with the front, too much strain on the smaller front axle and even the frame. Really hard pulls will come from the rear using the drawbar, I just need a strong front point if I ever get stuck.
Can't say I have done any serious pulls yet, but I'm betting on being able to pull trees!
/ Front recovery points... #8
Nice Job. It also gives you a nice anchor point for cross chaining if you move it on a trailer. Do the D-rings make much racket when you're working it? I've got several D-rings sitting around but I have yet to make a plate like yours. I've looked for weld on tie downs ( basically a piece of flat stock or round rod bent with a loop in it) but I haven't found any decent ones yet.
/ Front recovery points... #9
Nice!
I kinda did the same. This unit "sandwiches" the grill guard and the frame,
plus the tube goes back and intersects the frame adding rigdity;
No noise, brushogged the other day and can say i did not notice it at all. I was also debating using mounts for shackles, but went D ring for simplicity/multiple uses.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
2022 EZ-GO ELITE...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
