Roundup and rain?
/ Roundup and rain? #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I sprayed my plots today with 250 gallons of generic Roundup (Tractor Supply brand). As I was leaving, rain was threatening. I am not sure if it rained where I sprayed, but there was rain in the area. It would have started several hours after I finished. My question is: how long does Roundup have to stay in contact with folliage to be effective? Would a light rain several hours after application cause ineffective results? This rain was unexpected. Hope I did not waste 5 gallons of herbicide!
/ Roundup and rain? #2
As long as the chemical was dry you should be fine
/ Roundup and rain? #3
It depends on how strong the dilution was, how much was applied, what the temperature was, how dry the plants were, how long it was before it rained, and how much rain fell.
You will know in about a week. :thumbsup: I wouldn't worry too much.
A field next to me gets sprayed by a local company, who always insists on spraying all the way into the corner of the field. The area is clearly manicured lawn, (by me), and not part of the corp. The operator seems to be about as bright as a tow truck driver, so each year he sprays the grass, (along with of course 1-3 feet of my lawn along the property line). This year, I was home when he sprayed, and I dumped several FEL buckets of water on the grass in the corner, almost right after he sprayed it. Most of it still died. :(
/ Roundup and rain? #4
Straight from my jug of Round-up,
"RAINPROOF Protection: Rain or watering 30 minutes after application will NOT wash away effectiveness."
What does yours say ???
/ Roundup and rain? #6
I did the same thing a little over a week ago. Put out several 25 gallon tanks on some well established and fairly tall bermuda, fescue, bahaia and general weeds. I was not expecting rain but it came, and pretty hard. The round up knock off that I used said 2 hours. I must have met the criteria because the plots had lots of brown yesterday. Definitely, some grasses kill better than others. My application seems to have put a big kill on all weeds, and did fine witht he grasses except for fescue. May have to hit them again, but will mow first and see what it looks like.
/ Roundup and rain? #7
Next time this happens contact the company and the local ag dept as this is a violation of chemical application and is enforcable. Take pictures before and will help. You dont not have to deal with chemical overspray........ There was a similar thread on TBN where a land owner lost several feet each year of his hay/grass field after the neighbor sprayed his. Imagine the farmers take if you killed his crop every year !!!
OP you should be fine unless it was a big downpour within the hour of appplication. After 10 days you should see yellowing and wilting of the plants. I just did my food plots last week. Got them planted and had a little shower. hoping for more rain.
/ Roundup and rain? #8
As long as it was dry or on plants for a few hours your fine. Not all branded roundup is 30 mins i think some is an hour, other generics unless really rain fast kind is from a few hours to 6 hours. I think an hour in the summer is fine.
/ Roundup and rain? #9
I have the company that sprays around here on notice. They know that they will be coming out here with their check book, the next time they kill any substantial portion of my grass. They really don't care if they do, or not, since they a known around here for repeatedly doing it.
Unfortunately, the area I was mainly referring to is not my property. It is the front corner adjacent to my lawn. it does not get planted by the farmer, because it is outside the turning radius of the planter. It winds up an eyesore each year, because the local spray company kills the grass, and the weeds take it over. I used to kill the weeds and help the grass move back into it, but they keep killing it, so I gave up.
The farmers here consider most non-farm residents intruders. If the world was the way they think it should be, the land would all be theirs. So, you can't have a fair discussion of how to handle a problem like this. If you get on their bad side, they have lots of way of making you miserable.
/ Roundup and rain? #10
Hello HCJtractor,
How did your application turn out? Did the rain have any effect? I've wondered about this since I've had close calls with rain after spraying and always use the TSC brand (which does a great job).
/ Roundup and rain?
Turned out just fine. Everything killed. I went ahead and disked 10 days later and then used my Truax grain drill for the first time. Looking good. Already sprouting and deer already hitting it
6 Band Wooden Barrel (A61569)
6 Band Wooden...
2017 GMC Arcadia SUV (A61569)
2017 GMC Arcadia...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2021 KUBOTA KX033-4 EXCAVATOR (A62129)
2021 KUBOTA...
2016 Hyundai Veloster Hatchback (A61569)
2016 Hyundai...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
