Buying Advice Aurora Silent Diesel Generator
/ Aurora Silent Diesel Generator #81
I disagree. Gas generators do not "stack". It's totally not the same issue.
Howdy,
Stacking, That is a whole nother subject. I am talking about piston rings. I am talking about the field magnatism.
/ Aurora Silent Diesel Generator #82
Boy's, go back a couple of pages and re-read-try page 7. Wet stacking was why he had to tear apart the engine.
Field magnetism is re-established in milliseconds. You don't need to run it for any duration.
/ Aurora Silent Diesel Generator #83
Warming up the engine oil and drying out the generator head windings take a lot more time. Basically any mechanism needs to be run under similar conditions to operational use to make sure it works. A loose connection may not show up in a two minute run, but might fail after 20 minutes. I also make sure it will run my house loads at least once a year.
/ Aurora Silent Diesel Generator #84
I agree with your last post. I'm talking about the poster who wet stacked a diesel and now because he doesn't want to tear his engine apart again, went out and bought resistance loads and plans on always keeping it loaded over 50%. My gas genny is stored indoors in a heated area so there is no moisture issues. When I do loose power, I connect it outside and let it rip. Sometimes it's just powering some lights, the t.v., and small motors for the heat system, and that's a very small load. I love that it can just sip some gas during those long days of running. Like I said it would suck to have to worry about keeping it loaded over 50% because you worry about wet stacking. I only have to worry about too much load. It's a double pain to also have to worry about not enough.
/ Aurora Silent Diesel Generator #85
I wonder if this is exaggerated. I would think that there are many truck diesels that are not being run above 50% most of the time. Perhaps I did not read the article carefully enough. I can understand loading it periodically, but all the time.
/ Aurora Silent Diesel Generator #86
If I thought it was necessary to keep the genset loaded with resistance heat strips all the time I would buy a smaller genset instead.
I get a little humored by the guys who need a 50kw genset to get by with power outages. Unless you have a dairy farm or other critical need it might behoove you to learn how to get by with less. Might be good for the rest of the family to learn how to get by with less too.
/ Aurora Silent Diesel Generator #87
Good point!
Some of the generator websites have kW calculators to determine the best size for one's needs. Although I was initially considering a 15-20 kW unit, those calculators showed me I could do quite well with a 10-12 kW generator.
/ Aurora Silent Diesel Generator #88
I've contemplated getting a small diesel to replace my gas genny, but I think every design has pros/cons, and I'm coming to the conclusion that for small single cylinder air cooled apps, gas is better. I think I'll stay with petrol, for this, but I like the diesel tractor, but that's water cooled, with varing rpm's and load.
Also on a genny which must run when you need it, I can take apart a gas engine and make it work if there was a fuel issue, on the spot during a snow storm. No such luck with diesel injection system.
/ Aurora Silent Diesel Generator #89
All good now with bells on my toes!: Aurora Silent Diesel Generator
I replaced the injector pump and the generator is purring again! The exhaust runs clear and hot, and the tone of the generator is quite smooth now. I'll let it cool off over night and check the valve clearances in the a.m.
My gas generator has half the capacity of the diesel generator, so I needed a way to monitor the load regardless of which generator was connected to to the ATS. I installed current transformer/meters on L1 and L1 (before the load bank) so that I can see the load and reduce it reliably if necessary.
The CT/meters were 50A, and the maximum that I'd expect for either leg would be 30A (the breaker on the diesel generator). I put a second loop through each CT to set the range to 25A, and relabeled the meter faces for the new range.
I compared deflection between the single and double-loop CTs, and the linearity on the inexpensive meters was quite acceptable. I mechanically adjusted the meters so that the mid-scale reading matched my two other current meters.
Photos attached for your consideration.
/ Aurora Silent Diesel Generator #90
Re: All good now with bells on my toes!: Aurora Silent Diesel Generator
I know this thread is older, but researching Aurora generators and this site have been interesting. I like your meter set you installed I am thinking of doing the same for my Aurora generator for load balancing. My Diesel engine is made in the US by Perkins Diesel.
Paladin Dirt Sifter (A61166)
Paladin Dirt...
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A61165)
2015 Isuzu NPR-HD...
Tree Boom Skid Steer Attachment (A61567)
Tree Boom Skid...
2021 John Deere 1775NT Planter (A63109)
2021 John Deere...
TAKEUCHI TL12R2 SKID STEER (A62129)
TAKEUCHI TL12R2...
1979 AM General 6X6 Truck (A61165)
1979 AM General...
