I HATE CHAINSAWS! - HATE'EM!
/ I HATE CHAINSAWS! - HATE'EM! #1
Jim Miller
Kerrville, TX
2019 Kubota M62 TLB, Bobcat T 650 Trac Steer
Nothing is so hard to start!! I've got a Stihl MS170 and a Poulan Wild Thing and both are hard starting. I've got 3 weedeaters (one is so old I don't know what brand it is) and 2 blowers (both Echo) and they all use the same gas and oil mixture. No matter how much I neglect all of the weedeaters or blowers - they start on the 2nd or 3rd pull and run fine. But my chainsaws are almost impossible to start!! I just wanted to rant! Now I feel better!
/ I HATE CHAINSAWS! - HATE'EM! #2
I love my Stihls
You have to know the technique to start them is all, once you get that down you will love them as well
/ I HATE CHAINSAWS! - HATE'EM! #3
Buy Echo and get rid of the junk.:shocked:
/ I HATE CHAINSAWS! - HATE'EM! #4
Dunno about the Pull-on, but with the Stihl, try this.
Set choke full on
Pull 2 to 3 times till you hear it fire once
Set choke to half and pull one or two more times till it starts
Don't know why, but every Stihl I've ever run starts that way.
/ I HATE CHAINSAWS! - HATE'EM! #5
I love my echo weed wacker and always have, would never buy a Stihl, but NO ONE builds a better chain saw than Stihl
/ I HATE CHAINSAWS! - HATE'EM! #6
Here that??? Echo!!!!! pull choke, 2 primes and pull. Brrrrrrrrrrrrrrrrrrorrrrrrr.Starts every time.
/ I HATE CHAINSAWS! - HATE'EM! #7
Sounds like a carb tune issue to me (assuming you are choking the saw intil initial fire as mentioned above).
Those are both low end homeowner saws. The poulan......I wont go their. But did the stihl dealer adjust the carb before you bought it? Or assuming it is new, did you have it re-adjusted after it was broke in??
/ I HATE CHAINSAWS! - HATE'EM! #9
I disagree.
Disclaimer: THAT is your opinion, and this is mine:D
All I know is I have 2 - 29 year old Stihls, and 1-2 year old one, and the old ones will fire right up, and the new one is built as well as the old ones.
I know I would never buy another brand
I forgot to add that that I also have a Sthil HT 100 Pole Prunner and it starts fine just like the weedeaters and blowers. Someone commented that Stihl makes a great saw and I agree (after I get it started). Yes, I took the MS 170 into the Stihl dealer here in Kerrville and paid for them to do a complete tune-up. They said I had bad gas and a bad spark plug. They replaced the gas and plug. About 2 or 3 weeks later I tried to use the saw (with the dealer's gas) and I still had a tough time starting. Again, both of my saws run fine after starting and all of my other 2 cycle equipment start's and runs fine (using the same gas). Heck, I've even started using Seafoam to see if that helps. Nope!
I don't post very much on TBN - but - I read new posts almost daily and I really enjoy and respect you guys! I've learned a lot too. So, I felt like I could just share some frustrations!!!!!
Now - I feel better - again!
/ I HATE CHAINSAWS! - HATE'EM! #11
Set choke full on
That's exactly how my Dolmar starts. I looked at Stihl, but for the size saw I wanted I liked the Dolmar better.
/ I HATE CHAINSAWS! - HATE'EM! #12
In years past, I've owned 2 Poulans and my brother had a Stihl; never a problem with starting any of them.
/ I HATE CHAINSAWS! - HATE'EM! #13
Set choke full on
That is correct!
Once you follow this I am pretty sure you will have a whole new feeling for your saw
/ I HATE CHAINSAWS! - HATE'EM! #15
Take 'em to the shop and get them running right. I have a small Poulan and a larger Craftsman; they both start quickly even after sitting for years.
/ I HATE CHAINSAWS! - HATE'EM! #16
Gas that is 3 weeks old is marginal for the saw. I've bought about 4 of those quarts of premix at Walmart and used the fuel. Now I buy a gallon of non-ethanol gas, mix in the oil and a dash of Stabil and refill the quart metal cans. Seems to keep everything running great.
/ I HATE CHAINSAWS! - HATE'EM! #17
My 20 year old 16" McCullough gets used about once a year. I don't drain the fuel... but it starts right up on year old gas the next time I need it. Same starting procedure as previously mentioned for a Stihl, but I press the primer button twice first.
It's probably not the best saw in the world, but it has never let me down.
My BIL had the same saw, he loved it... until he backed over it with his pickup. He replaced it with a Stihl, and has trouble starting it... has tore the starter rope out of it twice in 2 years.
I guess the best saw is the one that works good for you.
Pete
/ I HATE CHAINSAWS! - HATE'EM! #18
When i was a logger, never had a saw more than two or three years before it was used up. Used whatever was available or if there was a deal I bought a couple of those. Used all the european ones and American Homelites , McCullochs and yes even Poulans. Never had a favorite (although always had a closeness to the Homelite 975) as they all started and ran like I needed them to so I guess they're all the same to me (professional saws that is)
What I did notice however was that everyone was cheapening up their saws. This had a two fold reasoning: 1. certainly for economy issues 2. there was a race as to who could make the lightest but still powerful saw so no, I could not say they were built with the same quality over a thirty year period no matter who was making the saw. It was simply impossible to keep the same durability that thicker plastic castings along with getting rid of metal casements if they were trying to lighten saws.
/ I HATE CHAINSAWS! - HATE'EM! #19
Don't know what you are using for oil but the high grade Stihl and Husky brands and probably some others already have stabilizer in them.
/ I HATE CHAINSAWS! - HATE'EM! #20
LD1 said:
I disagree.
LD1, if Mahindra made chainsaws, they would be the best. They don't make chainsaws, because they want to give someone else a chance to be the best at something. :)
(Note: 25.1 hrs and 12.5 weeks exp...)
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
New/Unused AGT Industrial LRT23 Mini Skid Steer (A65583)
New/Unused AGT...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
