Box blade leveler for L2500
/ Box blade leveler for L2500 #1
Davidlx
Western Noth Carolina
Kubota L2500
I do a fair amount of road maintenance in my community and at times want to tip my box blade either left or right. It is a slow and tedious job using the turnbuckle on the right arm. I have seen crank handle units but Kubota apparently does not feel we need these and does not sell them. Anybody know where I can get one to fit my L2500?
/ Box blade leveler for L2500 #2
Do yourself a favor and get T&T (Top and Tilt) you will never have to get off your tractor to adjust the box blade again...well worth the expense for just about any BB work IMO...
/ Box blade leveler for L2500 #3
/ Box blade leveler for L2500 #4
i have seen the rotating handles, i think you are talking about. that work much like the trailer jack up by the ball hitch. that you crank. but i honestly do not remember seeing any sort at local stores or online websites. granted i have not went looking for the specific type of turnbuckle.
doing a lot of seat time for road maintenance, i would say TNT (Top aNd Tilt) instead of a turn buckle on right side, it gets replaced with a hyd cylinder, and same thing goes for TOP link. and you adjust with a couple hyd valves/levers.
i never realized it, till another post awhile back showed up. but getting correct size "tilt" cylinder. that will allow you small adjustments both up and down. is necessary. and if you buy a kit, you may just get a cylinder that has a long rod. that only levels or goes down for a large right tilt. vs being a shorter rod on cylinder that allows a little bit left and right tilt but no large/longer titling.
the cost of hyd cylinders for TNT and then possibly needing another 1 or 2 rear remotes and valves can get a little costly, but time wasting gas as you deal with manual adjustment. vs moving a lever that lets you adjust things as you are moving.... and high chance for a much better final results with TNT vs manual adjustments.... TNT could pay off fairly quickly.
/ Box blade leveler for L2500 #5
If you get TNT, move the adjustable link to the left side. You will have more adjustment to compensate for cylinder length, to a point. And, if you don't have remotes but want to get them, get valves with detent float positions. Works great with a box blade.
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
207270 (A52708)
207270 (A52708)
John Deere 6105D Tractor (A64047)
John Deere 6105D...
445 (A63290)
445 (A63290)
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2010 DMI 3200 Fertilizer Applicator (A63116)
2010 DMI 3200...
