Need a little help with decision.
   / Need a little help with decision. #1
Pa Pa Jack
Hodges, SC
Mahindra 3016
I have several large areas to till up for food plots. I want to try to disturb the soil as little as possible, but cannot afford a no-till drill set-up. After doing some reading, I have come to the conclusion that a chisel plow would be better than the rototiller I already have. My one big question, in my mind at least, is what is the difference between a cultivator and a chisel plow. They both seem to do the same thing.
   / Need a little help with decision. #2
What I have done is use my home made 5' cultivator/hiller/digger/you name it attachment.
I have used it with different combinations of shank spacings and digging shoes.
All seemed to work OK. Then just broadcast mixed seeds and go back over with a shallow setting.
Seems to have worked OK for this part of the country so far.
Here is a picture with all 17 shanks (3-3/4" spacing in 5' staggered front and back)
Wheels set to dig 2" deep on hard ground.
Good luck
   / Need a little help with decision. #3
I found a video on YouTube in regards to the dfference between a cultivator and a chisel plow. My PC is acting up. Perhaps you can search YouTube and search for some videos? Best wishes.
   / Need a little help with decision. #4
For what you are wanting to do a boxblade rippers might be a good solution too. I would probably just till it lightly with the existing tiller and use a rake or harrow to cover the seed. Getting the seed where it needs to go would be your problem without using a seedbox and drop tubes, broadcasting will require alot more seeds.
A chisel plow is made to penetrate alot deeper than a cultivator and has rigid shanks for deeper tillage. You could run it shallow but how are you going to get the seeds where you need them?
   / Need a little help with decision. #5
Another option is to get a 8' disc used - they can turn over the first few inches of soil quickly and dont care about the roots or rocks that may be present - this might be the most efficient as well.
Then seed and disc this in more lightly across the grain from your first pass. As Jenkins said you dont want a chisel plow they go 8-12" deep.
   / Need a little help with decision. #6
I should add that in the Rocky Mountain chain as we are both in you can't avoid hitting some rocks with the tiller. I have been at it for several years now and have lost two tiller blades but jumped alot of rocks in that time. Just make sure you have a forward rotating tiller.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2024 Quality Steel Deck Over Tilt Trailer (A59814)
2024 Quality Steel...
Landhonor Skidsteer Portable Screener (A59814)
Landhonor...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
