first tractor
/ first tractor #1
klyders
shepherdstown,wv
none
Good day to all,
Need advice on a good tractor w/bucket for 40 acres. Rolling acreage, some fenceline (3000 ft) to clear.Any responses would be helpful, along with basic implements, etc.....what a great site!
/ first tractor #2
I will not suggest any certain make or model, because everyone has different varying opinions. I would definitely suggest 4WD. If you review the forums here on TBN related to specific makes and models, you will acquire a lot of insight in helping you choose. The following website will supply you with specs. Hope this helps. Best wishes. BTW, good to have you aboard. TractorData.com - information on all makes and models of tractors
/ first tractor #3
Personal preference here...
First tier I like New Holland, Kubota, Massey, Deere, Case-IH, in no particular order...
Second tier I like Mahindra, LS...
Third tier anything else...
I would stick to a 40 to 70 HP utility sized tractor...
That will give you more options and capability than a large compact...
FEL, bush hog to start with...
More implements later...
/ first tractor #4
i would stick to 60 hp and up i have a 40 hp and its to small for me the fel cap is to small the 3 pt is tiny the tractor is to light it spins when trying to scoop stuff up in bucket
/ first tractor #5
If your just gonna clear 40 acres...hire it out. If your gonna use the tractor to farm the 40 acres after it is cleared...go with around 60 hp, transmission choice is up to your personal preference. Like has been mentioned, people are faithful to their brands just like fords and chevys, so try a few seats and see what fits ya.
/ first tractor #7
I'd add Kioti to the tier 2 machines, but agree beyond that.
You will get more done with a utility tractor than a compact utility tractor (CUT). A 45HP utility would likely be more powerful than a 60HP CUT, but the CUT is much easier and user friendly to drive. Since you're new to tractors I'd recommend sticking with a CUT just so it's easier, also from owning and operating both, HST is a big plus.
/ first tractor #9
If I were going to mow 40 acres regularly I'd want a 15ft.+ batwing style rotary mower. To pull it effectively you'll need about 75 horse power at the pto. If you're just going to mow, a geared transmission is fine. If you're planning on a lot of loader work I would go with a shuttle shift or hydrostatic transmission. With a machine this big you could probably get away with 2wd but 4wd is sure nice to have. As I recall Shepherdstown gets about the same amount ot snow as we do here in Baltimore County. I don't know if scraper blades are availabe in really wide widths, but it's what I'd use for snow up to 18". You will probably want a cab for mowing in the summer heat and R1 tires. I would be looking at JD, Massey and New Holland for a machine this big.
/ first tractor #10
New Holland and Case compact tractors (Ag tractors is a different story) are also second tier. All the New Holland and Case compact/compact utility tractors are made by LS Tractors now; not the same quality as the older compact tractors made by Shibaura. I would say Kubota, Massey and Deere are tier one and Kioti is in the middle between tier one and tier two (it is a good tractor).
You might be better off with an Ag Tractor (bigger, heavier, and a little more stability). Is the acreage open, open with small scrub, wooded or a combination of open and wooded? What are you looking to do with the property? Create a meadow, plant crops, hayfield or etc.?
/ first tractor #12
Depending on your budget you can get by with a 25 HP with 5 foot mower if you have unlimited time (retired). A 15 foot batwing mower for 40 acres is ludicrious. NO need to spend that kind of money for a mower and75 HP tractor to pull it with that you wont need but maybe twice a year. We have 40 acres here and for the first year we mowed with a 4 foot mower and a 750 JD tractor (19 PTO HP). Sure its slow but it got the job done for about $4500 total investment and the place was a grown up mess that hadnt been maintained in over 5 years. We added tractors as time passed for some specific duties. A 50 HP is plenty large and a 6 foot rotary mower is wide enought to give pretty good performance time wise while still able to mow between most trees etc.
I recently acquired a used Kubota B26 TLB (tractor-loader-backhoe) and wish I had bought a backhoe as first tractor. It is soooooo handy for removing the yearly rock crop here and planting trees, digging trenches and even clearing scrub brush, removing stumps etc. The B26 is likely too small for maintaining 40 acres but Kubota does make models up to about 50 HP. JD also has a model 110 that would be a capable tractor for you to mow with also. I dont have any experience with them as to ease of backhoe removal, but the Kubota is a 5 minute job. The only time I have removed mine was when I bought it, the previous owner showed me how to unhook and hook it up. I bought an LS P7010 with cab and HVAC that I used for heavy lifting and mower, because the air conditioner is so nice. It is much too large to get into tight spots with but the price when I bought it 2 years ago was = to a 50 HP NH, Case, Massey and Kubota. It is nice for FEL use in digging and hauling dirt and rocks as the bucket is huge, but I use the Kubota almost daily for just about everything. We used it tag team 2 days ago moving some very large rocks. What I couldnt get to scoop up in the LS bucket, I used the B26 as a bucket filler. The backhoe with hydraulic thumb was also great for picking up smaller rocks and putting them in the LS bucket, much easier on the back.
As of now, we have 4 tractors 750 JD with post hole digger mounted most of the time but seldom used now as all the fencing is up, New Holland boomer 2030 with FEL and 6 foot bush hog, LS 7010 with 7 foot bush hog not used as a mower in 2 years due to the drought but does make an nice counterweight for the FEL work and of course the Kubota B26 which replaced a Yanmar 4220D which I sold to my sister with a 6 foot bush hog.
We have way more equipment than needed but it sure is nice to just go crank up the tractor with the equipment on it that you need to use.
One thing that is not tractor but very handy is the UTV's we use everyday for transport and hauling tools and stuff for mending fences etc.or I have a Kubota RTV 900 and my brother in law next door has a JD Gator. They get more used than the tractors and I thought when my B-I-L bought the gator it was just fancy but after seeing the many uses, I got the Kubota with hydraulic dump bed, 4 wd and hydrostatic transmission that can pull logs, anduproot small sapling via chain. Also very handy to have on the farm.
/ first tractor #13
i have 40 ac with hills and my JD 4720 cab with 66hp is all the tractor I need. good luck
2019 International LT625 Sleeper 48 (A62613)
2019 International...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
Generac QT04854 Anax 48kW Generator (A61572)
Generac QT04854...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
