Hydraulic Tools?
/ Hydraulic Tools? #1
Phunge
Happened to stumble on these hydraulic tools by Stanley: Handheld Hydraulic Tools
Does anyone have any experience with these? Noticed that most of them run on 7-9gpm -- would work well with a 3x20 machine?
/ Hydraulic Tools? #3
Look mighty expensive$$$.
/ Hydraulic Tools? #4
Alot of them i don't think would be a great fit........ having to drag around hydraulic hoses (two of them for everything), the drip when connecting / disconnecting , and as has already been mentioned, price. I will admit however, I've seen a fair amout of pole saws, pruners, and chainsaws 'used' on Craigslist and been tempted. Especially the polesaws..... I think i'd actually use one occaisionally.
/ Hydraulic Tools? #5
I have an older Stanley CS07 hydraulic chainsaw, and I have run it off my
Kioti tractor, even tho this older saw has closed-center hydraulics. The
speed was good, since the reqd flow rate is compatible, but the max
recommended pressure is 2000psi.
That pressure limitation is true of many other hyd chainsaws and other tools, too.
BTW, I also have a new Fairmont hyd c/s and Reliable hyd pole c/s here. Both
run at 7-9 GPM and 2000psi max as well. They are switchable between open
and closed-center hydraulics, which is great. I suspect that older hyd power
supplies ran closed-center, mostly, and open-center is now more common.
Hence the backward compatibility of these new saws.
I am waiting for some 2000psi cross-over relief valves that I have on order,
before I test the latter 2 saws.
IMO, a tractor is an awesome portable hydraulic power supply.
CREEP FEEDER W/ CALF RACK (A63290)
CREEP FEEDER W/...
2022 J&M TF212 Rolling Harrow (A63116)
2022 J&M TF212...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A59910)
2005...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
PALLET OF DISC HILLERS (A63290)
PALLET OF DISC...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
