Man up
/ Man up #1
Sprocket1
North Cen. Mo.
JD2305 JD5205
How many of you with a 2305 have never or very seldom grease the driveline u-joints? You know, the one near the starter ring and the one in front of the transmission cooling fan.
The u-joints are just the right size to make it nearly impossible to get a grease gun nose on the zerk. I had to grind down a regular nose to get mine greased. A needle adapter doesn't stand a chance of getting grease into the zerk.
/ Man up #2
My X748 has one drive shaft zerk that is a real jerk. I tried the needle point too. I ended up doing what you did and ground one down. I grease them all on schedule. A failure can break a lot of stuff.
/ Man up #3
I have an x748, and I use a needle to grease the driveshaft zerk. I use a small gun with a steel tube and a squeeze lever; one hand operation. I can reach up there with one hand and squeeze the lever. It goes right in. I also ground down a regular grease gun fitting, but I think the needle is way easier.
/ Man up #4
Trade in your 2210s, 2305s, and X748ses, on a 1026R. A standard tip works on the rear joint, and a needle works on the front.
/ Man up #5
Do all 2305's have these fittings. I have a 2011 and after reading about this issue looked for mine and could not find them. So either I need to look harder or don't need to look at all. Please advise
Thanks
/ Man up #6
And the advantage is?????
/ Man up #7
No grinding your grease gun tip. No guessing if the zerks are even equipped on the joints, and No body panel removal to access them.
/ Man up #8
Problem is....I would have an inferior tractor to my X748SE for mowing. The ride and handling on a 748 is not matched on a 1026.
The 748 could probably be done with a needle point if someone younger than me did it. It also sounds like you had to buy a different gun than I have. There are no panels to remove on a 748. The ground down fitting is fairly easy to do. I can't get enough pressure on the needle point with my old arthritic hands.
/ Man up #9
Thank You. I'm sure that the OP will find your post very helpful. Thanks again for sharing your technical insight.
/ Man up #10
Yeah, I'm rather fond of my x748se as well. Not that I wouldn't like a 1026R.....
/ Man up #11
It's really hard to beat the comfort, maneuverability, and ride on the 748SE. It's a heck of a mower. I also use a 54" blade for small snows where the L3400 blower is overkill.
I'm sure the 1026R is really nice for other things but would be a bit too small for my needs for loader work or ground engaging.
I hope we get rain again so I can mow. It's been 6 weeks with no mowing here.
/ Man up #12
I thought the topic was "manning up" in regards to the intermediate driveshaft? My suggestion is based only intermediate driveshaft serviceability. You are correct, the R is severely inferior to those machines in most other aspects of owning operating.
/ Man up #13
So you think "manning up" means to trade your unserviceable inferior tractor for a 1026R. That really was a useless comment to start with.
/ Man up #14
Thanks
Look harder, all 2305's have the hidden zerks. I use a needle point on an air grease gun to grease mine. Not fun.
/ Man up
My tractor has sealed u-joints on the front wheel assist drive shaft. I don't understand why the u-joints are sealed on it and greaseable on the much harder to get to engine to transmission drive shaft. Maybe rpms are much lower on fwa shaft.
/ Man up #16
You're too sensitive about your GT! I'm not the one who started off the inferiority. The point is: in an age of "non-serviceable" and "lifetime lubricated" drivetrain componets, there is hope with Deere. From all accounts, the new SCUT design offers increased ease of servicing your intermediate shaft. Wish I could say the same about the rest of the equipment in my life. For example: google checking, or changing ATF in a Pontiac G8 to see what I'm up against.
End useless comment.
/ Man up #17
I thought that was sarcasm at first but I guess not.
BTW: The grease fitting on our X720 on the drive shaft back near the tranny is accessible with a reg. pistol style grease gun with a flex hose if it's in the right position, no grinding or needle greaser. It appears there's very little movement in that U-Joint so it shouldn't need a lot of greasing. I may be wrong but I don't think it's mentioned in it the manual, we found it by accident.
/ Man up #18
That's how I first took it. I don't like smart alec remarks. But, I'll give this one the benefit of a doubt.
SECTION OF PALLET RACKING (A63745)
SECTION OF PALLET...
STAINLESS STEEL BAKERS RACK (A63745)
STAINLESS STEEL...
FORD 555D BACKHOE (A63290)
FORD 555D BACKHOE...
6500 GAL PLASTIC STORAGE TANK (A63745)
6500 GAL PLASTIC...
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59910)
2019 UTILITY VS2DX...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
