IP is the protocol that's used by your PC to talk to the internet and other nodes on your local network...eg. printers, appliances, other pc's, the router...etc.
Typically wireless routers also run DHCP services which provides IP addressing to nodes on your local network that are set up to be DHCP clients (a common network configuration).
Typically a home wireless router has some extra RJ45 ports on the back. You need to run a physical connection from the RJ45 port on the back of the homerun to an available port on the wireless router.
When you turn on the homerun (which is set up with a DHCP client config), it will broadcast on your network to locate a DHCP server. The server (running on the router) will assign the homerun an address which will allow it to communicate on your network... When you start the hd homerun client (or other media client) on the MAC or PC it will scan the network, locate the hd homerun and establish a connection to it over the local IP network.
So to recap, the homerun receives digital OTA broadcasts from the antenna and converts that signal to IP protocol. The hd homerun client software that you install and run on your PC (this same technology comes packaged with Windows Mediea Center) scans for the receiver when you start it up and makes a connection to the receiver. Once the connection is made the software provides a channel manager, volume control, DVR..etc...that you can use as an interface. I have a TV connected to a PC in the TV room. I run Windows media center to receive the OTA signal through the homerun and I also use the browser to read the paper, stream Charlie Rose or Hulu etc...
I don't think the hd homerun supports satellite antenna signals ..it does support cable and regular digital TV antennas. There may be something out there though that does...so look around.
Hope this helps you ....and good luck with it.
