BX Broken front axle
   / BX Broken front axle #1
V1Rotate
New Holland TC 29D
I noticed that the steering stop bolt is broken off for the right front wheel, it looks like the casting snapped off from the steering knuckle. Has anyone ever seen this before? If I can find the missing part that broke off can it be welded back on?
The tractor is a BX 1500 with only about 300 hours on it. I included a picture of the right side which is broken and a picture of the left side for comparison.(You'll see that the left side is leaking, any ideas about that?) Front  axle 1.jpgFront axle 2.jpg
   / BX Broken front axle #2
I've seen something like that on a L3650. Usually caused by stress like turning the wheel when it is locked in place by a rock, dirt, stump, or the like.
The best solution is to replace the broken part. Welding on cast is iffy at best.
It will need a new seal so that can be taken care of at the same time. The leak was not related to the break.
   / BX Broken front axle #3
Hard to say if it could be welded for sure without testing it but I would guess that it could be welded by a competent welder.The part should come off to fix it properly .If the casting is cracked,I probably would buy a new part but if it is just reattaching the block,it should be alright to weld it.Having the piece would be best but the part could be made out of steel and welded to the casting.There are various welding processes that would work but I would TIG weld it with a Certanium 423T rod.You would have to judge the cost of repairing verses replacing.Just my opinion but I have been in the welding repair business for quite a few years.
I am still looking for the part that broke off, it's out on the lawn somewhere. The only welder I have is an AC stick welder, so if I understand, I probably shouldn't try to weld it, just replace it?
   / BX Broken front axle #5
With only 300 hrs. on it the tractor should be under warranty unless it is rarely used. Check with a dealer.
Kubota Insurance may even pay for it if you have a policy. It would have had to be in an "accident" of some sort.
kcender indicated that it might be weldable by a pro but by an AC unit and casual welder would not be a recommendation.
BTW, the replacement repair cost for the L3650 totalled right at $1000 at a Kubota dealer.
The tractor is a 2003 so it way out of warranty.
   / BX Broken front axle #7
I believe you want part #K2511-15420 (there may be a supercede #)
Lashley Tractor Sales has free shipping for parts not considered WholeGoods,
PLUS there pricing is almost always lower then the standard fare.
CLICK HERE , Enter under model just "BX"
Verify the 1500D is your unit and it is the right part number and ask this guy for a price.
For MANY reasons I now go to Lashley Tractor Sales FIRST and do not bother
shopping around anymore. Free Shipping over 50 and the best price and service
can not be beat "."
They are consistantly less expensive and they get me my parts fast.
   / BX Broken front axle #8
I would say you are correct.If it were my tractor I would try welding it as I would be out nothing but my time.It will take a fairly experienced welder to do a proper repair on this.If that is not you then it would be best to get a new part or get a price on repairing from a welding shop.
   / BX Broken front axle #10
Do you have a front end loader on? Front weights?
Lot of weight on the front and no rear ballast on the 3 pt hitch is bad news for the front axle.
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2018 Wacker Neuson WL 38 (A52128)
2018 Wacker Neuson...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
71069 (A49346)
71069 (A49346)
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
