air horn
/ air horn #1
Railbender
northwest Tennessee
kubota 5740 hstc-3
I know mr. 4shorts had a post about putting an air horn on his kubota 5740 sometime ago and was wondering how it was holding out. had read some reports on
the Stebel horn that they were not too good in dust and vibration . would like to put one of some kind on my 5740 and also my jd. one on jd died and the other sounds
sick. any thoughts on this ?
/ air horn #3
You can add a 12V air compressor and small air tank, then install any type of air horn you want. They make air compressors that run off your fan belt too, if you have lots of money to throw at it...... :) If you look around on Dodge/Chevy/Ford diesel truck forums you will get lots of hits on air horns..... Good luck, Jerry
/ air horn #4
Don't some companies make a 12 volt electric one piece air horn that would work?
/ air horn #5
The company that the OP mentions - Stebel - does make them. I had one of theirs (the Compact Truck Air Horn) on my cargo van - nice horn and tone - but it got trashed due to water/salt spray .... possibly due to the mounting location I chose.
Might fare better on a tractor if you could find a mounting location that was protected and dry.
/ air horn #7
/ air horn #8
PhysAssist said:
Also, Harbor Freight has a one piece compressor and dual air horn units called "The Bad Boy" that they sell for about $5.00 less than AutoZone about $39... before the usual 20% off coupon. But you'll have to buy a horn switch elsewhere.
Yes it's the same one as on the WOLO website, but way cheaper...
/ air horn #10
Thanks for posting the Link.
Bad Boy Air Horn - Save on this Bad Boy Air Horn at HFT
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
NEW HOLLAND T4.105F TRACTOR (A62130)
NEW HOLLAND...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
