Quick Hitches quick hitch problems
/ quick hitch problems #1
94BULLITT
Super Member
USA
yes
Well I got a quick hitch from harbor freight and was that a mistake. I read the owners manual online before I made the purchase. It said nothing about needing bushings for the lift arms which I am 99% sure I need (look at my pics and tell me for sure). From what I read a quick hitch goes from cat 1 to cat 3 on the lift arms and toplink. So I can make my own adaptors for the lift arms out of bushings from tsc. That part is not too bad. The toplink is where things get bad. I have a woods lr72 which is qh compatible. When you use a qh you use the bushing under the toplink pinhole, right? The hf qh toplink hook will not go all the way down into it even off of the qh. The next problems is I can only get one bolt to into the hook to come close to working. The bracket where the toplink hook goes is wide than the rake so it will not work. What do I need to do to get the toplink to work? Did they make the toplink hook wrong?
/ quick hitch problems #2
Yes you need bushings. Most of the HF models I've seen go to cat 2 but yours looks like it will take cat 3 bushings. Now on your top link does the hook go completely into the bushing? And also seem that the top hooks are not made to stick far enough out,
/ quick hitch problems #3
That top hook looks like it doesn't have a snowball's chance in **** of fitting the implement. Whenever this happens to me I just think.. "ahhh well, the Chinese got me again!"
When I see that the Chinese finally grasp the concept of interchangeable manufacture, which the rest of the world has been using since the industrial revolution, some of their products might actually perform their intended function, and I might feel a wee bit less ambivalent toward them. I'll know they've made a start when I finally see a 1/4-20 screw fit a corresponding 1/4-20 nut, instead of hardware that is either faaaar too loose, or needs to be forced together with a breaker bar.
I have a tuffline blade that is cat 1 and 2. I tried a lift arms pin out of it in my qh and it was small. I was going to take another picture of the toplink hook and realized that it if I grind a little off of the hook it will fit but it still will not stick out far enough.
The Chinese are supposed to be good at math but they can't do conversions to inches to metric.
/ quick hitch problems #5
All QH require bushings. So that should be no big deal. Top hook is another story. Looks like the only way it would work is to weld a piece of metal to the back and drill holes for it to mount.
I got the top hook so it will fit the bushing. I guess I am going to have to make a adaptor for the tophook to set it back.
/ quick hitch problems #7
Mine had the same problem. I removed the bolts from the top hook and riveted it in place with mild steel rod at 15 inches above the bottom(standard) so it would fit between the uprights.
You would lose the adjustable height, but that was useable with all my implements.
An alternative is to get the top adapter and not use the hook.
http://www.tractorbynet.com/forums/...-frieght-quick-hitch-toplink.html#post1630946
Bruce
http://www.tractorbynet.com/forums/attachments/117801-harbor-frieght-quick-hitch-toplink.html#post1630946
Bruce
Where the hook bolts on is too wide to fit between the area where the toplink hooks. I am either going to make a adaptor or buy the adaptor to fit non qh compatible equipment.
/ quick hitch problems #9
Bullitt- I had the same problem as far as front to rear distance. I ground part of the bracket from my implement and it worked fine. I also replace the 2 bolts that hold the hook to the Qhitch and put in pins and gained even more clearance. I did not have the width clearance problem you have.
I tried after grinding and it still would not work so I welded a piece to it. I was going to sandblast the hook but believe it or not the paint or powder coat is stuck to it pretty good. All I have to do is paint it. I want to get some pins instead of bolts so I can adjust it easily. I need to make a adapter or buy a adapter for non-qh compatible equipment. Some equipment I may be able to modify. Can someone post a pic of a bushing on their lift arm? I have heard of some people adding grab hooks to them. Are there any upgrades I should make to it before I paint the qh? Is there anything different about the i-match?
Here are the pics
Here is a crappy video of it in action (Click on it to play)
/ quick hitch problems #11
I like your fix. Good looking welds.
/ quick hitch problems #13
Very nice! Better patent your idea, so they don't steal your idea!
/ quick hitch problems #15
Good fix and as has already been said, "nice welds". This has been discussed before and there is a bit of agreement, "the lift pins need to be bushed up" and a bit of disagreement and that is what size to bush up to. Every cat one hitch I've messed with had Cat 2 size hooks. The bushings are simple, just get a lift arm bushing from cat 1 to cat 2 and put it on the lift pin, put your lynch pin in and leave it.
All of my equipment that I had originally outfitted with cat 1 pins are done that way, the newer stuff I simply put on cat 2 pins to start with. Some folks believe that a cat one QH uses cat 3 diameter hooks. I can't find anything that states that cat 3 is the correct size hook for a cat 1 hitch, If your does, well ok, none of my hitches do.
I think I may do to my top hook what you did to yours. I can hook to anything I have but some things would be a bit easier if the hook stuck out a bit farther. I'm gonna weld up the old holes tho' :)
/ quick hitch problems #16
My Harbor Freight hitch is for Cat 3. I have to use 2 bushing for each pin.
JD I match pins are Cat 3, too, I believe:
Optional iMatch Quick-Hitch allows for easy implement hookup
Upper bushing
Inside diameter: 0.76 to 0.77 in.
Outside diameter: 1.24 to 1.25 in.
Lower bushings
Inside diameter: 0.88 to 0.89
Outside diameter: 1.43 to 1.44
/ quick hitch problems #18
This is fun... :)
On page 9 of the QH-15 documentation
"Beginning with S/N 388293 and above, two 320-
048D lower bushings are shipped tied to the Land
Pride Quick-Hitch. Install lower bushings onto the
implement’s lower 7/8” hitch pins. This will provide a
tighter and more secure mounting in the Quick-Hitch
lower hooks."
The bushings are 1.44 inches in diameter which is cat three size. Based on this, would could assume that prior to the mentioned serial number the hooks were sized for cat 2.
HOWEVER!!!!
on the table telling what pin sizes are acceptable but the QH-15 it states,
"Various pin sizes up to 1 1/8” can be
securely locked in."
1 1/8 inch is cat 2. Even their documentation isn't standard. LOL
use whatever floats your boat. :)
/ quick hitch problems #19
This is fun... :)
lower hooks."
HOWEVER!!!!
Yeah, definitely... Use whatever. Cat 2 to Cat 3 is certainly better that Cat 1 to 3. The ball ends on stock lift arms provide a good fit on implements, so I try to duplicate that. I like to keep shock loads as low as reasonably achievable (ALARA... An acronym I despised from my old Nuke days) so I bush accordingly. But, to each his own...
P.S. Proof once again that we can never assume anything... The only difference with the serial numbers prior to the one you posted, is that the QH-15 came with NO bushings, as in "purchased seperately.," For what LP charges, a set of bushings to get you started is the LEAST they could add!
Here is some stuff I found on 3ph dimensions and I-match. I got cat 1 to cat bushings then cat 2 to cat 3 bushing with a pin hole in them for my adapters.
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Wacker Neuson HI400 Heater (A61166)
Wacker Neuson...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
2008 Chevrolet C4500 4x4 Altec AT200A 30ft. Bucket Truck (A61568)
2008 Chevrolet...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A62129)
2016 JLG ECOLIFT...
