Need help 2004 Kubota L48
/ Need help 2004 Kubota L48 #1
KubotaL48
houston, Texas
Kubota L48
Hi here,
When i go to start my L48, it turns on and then immediately dies. I cant figure out what is causing this.
Battery cable that connects to the starter shorted out by hitting the engine block, cable was replaced but now will only run if the key is held in the on position.
/ Need help 2004 Kubota L48 #2
Might be the fuel shut off is not working correctly or the switch that opens it.
The electrical shorted out on the trailer, after that was fixed. it will crank but when you let go of the keys it dies. checked the fuel shut off,
Does any one have pictures of where the fuel cutt off is?
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
Lifts (A61567)
Lifts (A61567)
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
