Need help 2004 Kubota L48
   / Need help 2004 Kubota L48 #1
KubotaL48
houston, Texas
Kubota L48
Hi here,
When i go to start my L48, it turns on and then immediately dies. I cant figure out what is causing this.
Battery cable that connects to the starter shorted out by hitting the engine block, cable was replaced but now will only run if the key is held in the on position.
   / Need help 2004 Kubota L48 #2
Might be the fuel shut off is not working correctly or the switch that opens it.
The electrical shorted out on the trailer, after that was fixed. it will crank but when you let go of the keys it dies. checked the fuel shut off,
Does any one have pictures of where the fuel cutt off is?
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
