Need help 2004 Kubota L48
   / Need help 2004 Kubota L48 #1
KubotaL48
houston, Texas
Kubota L48
Hi here,
When i go to start my L48, it turns on and then immediately dies. I cant figure out what is causing this.
Battery cable that connects to the starter shorted out by hitting the engine block, cable was replaced but now will only run if the key is held in the on position.
   / Need help 2004 Kubota L48 #2
Might be the fuel shut off is not working correctly or the switch that opens it.
The electrical shorted out on the trailer, after that was fixed. it will crank but when you let go of the keys it dies. checked the fuel shut off,
Does any one have pictures of where the fuel cutt off is?
Tooth 35in Excavator Bucket (A50322)
Tooth 35in...
2014 International Durastar 4300 Terex BT2047 47FT 10 Ton Crane Truck (A50323)
2014 International...
Chipper (A50774)
Chipper (A50774)
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
