New tractor
/ New tractor #1
ST98
Eastern,PA
Kubota L3540
Hello all,
I'm looking at purchasing a new bota. I was thinking a B3200 but I've heard a few things about excessive engine vibration on them. Of course that concerns me. Do any 3200 owner know of this or is this bota legend of tractors past? The mid PTO is a must for me or I would jump right into the L series. So that would leave me with the gl series but I'm not sure how much the mid pto option is. My dealership wasnt real helpful about the 3240, maybe cause none were on the lot. Any insight would be appreciated. Thanks
/ New tractor #3
I have a L3240HST and I do not notice any vibrations, but then again I don't have a mid pto. One of my local dealers said it would cost around $500-600 to install a mid pto on mine. Take a look in the private party ads at the bottom of TBN home page, I have mine for sale. I just want a larger tractor.
/ New tractor
I've only heard of vibrations in the b3200 not the L's. It'd be used for fel, back hoe, tiller, snow removal and maybe some brush hog work around the property. Unlike everything else I've done I'd like to by the right piece of equipment just once.
/ New tractor #5
My first new tractor was a 2009 b3200. Yes, It did vibrate, but I really only noticed it when I would "think" about it; meaning that while working and concentrating on the task at hand it never bothered me. I did end up trading it for a gl3240, but not due to vibration issues.
/ New tractor
If I may ask why did you trade?
Thanks
/ New tractor #7
Why do you need the mid pto? Front mount snow blower? You can also use rear mount snowblower or just front mounted blade, no mid pto required. Philip.
/ New tractor
May want to use a mower or snow blower in the future. Also I'd rather have it on and not need it versus needing it and not having the right tractor. I'd like to buy only one tractor.
/ New tractor #9
My opinion and experience, mid-mount-mowers are a pita, unless you do allot of trimming and plan to leave it on there most the time, which is not ideal for fel, back hoe, tiller, and bush hog work. Go with a 3-point rear mount finish mower, same results, much easier to take on and off. Front blowers are very nice, but very expensive. Have you priced the sub-frame, blower, and controls yet? Philip.
/ New tractor #10
All motors are going to have some vibration, esecially a small diesel. One thing I do not like about the b series is no skid steer quick attach on the fel. A mid pto will reduce ground clerance. You could run a rear finish mower and a loader mounted snowblade, then a l would be a option. A grand l would be really heavy (6000lbs) for mowing your yard. If you are going to be doing much rough cut mowing I think you would be happier with a l sized tractor over a b sized tractor.
/ New tractor #11
3 cylinders engine have more vibration than 4 cylinder engines in my experience. The 4 cylinder engines in the GrandL have twin balance shafts installed, very smooth.
You could run a rear finish mower and a loader mounted snowblade.
Similar to what I do, works well.
I mow my yard around the house with a lawn mower. I use my GrandL to mow the outer grass areas. L3940 turf tires and rfm, does a great job, not too heavy, does not leave tire marks. Plus, turf tires are great in snow.
Philip
/ New tractor #12
I've has a B-Series for about 7years. It's been a trouble-free tractor but if I could do it over I would have purchased a smaller-sized L-Series tractor instead. The stronger frame along with stouter hydraulics would have been a blessing. I use my B for tilling a garden and mowing outer ereas. Also, I do not like the mid-mount mower set-up. I am going to sell my mid-mount Kubota deck and buy a high-quality rear mount finish mower. Don't try to skimp or get by with barely enough power and size. It'll be cheaper in the long run to get all the tractor you need the first time. Last of all, the HST was worth every penny. No way would I want to do all the mowing I have to do with anything else.
/ New tractor #13
Philip
Yes a 4 cylinder is smoother than a 3 cylinder.
/ New tractor #14
I owned the B3200 TLB along with a BX23TLB with a mmm, they are as Philip said a PITA!A woods 72" RFM is what I have now on my L3540 with R4's and no issues with lawn, but of course some simple rules are followed , no mowing when wet , no sharp turns , no different then with my Garden Tractor. I never had an issue with the B3200, but I'm so glad I traded up to the Grand L 3540. Hope this helps?
DevilDog
/ New tractor #15
A mid pto on a 3420 retails for $377. You can build tractors on kubotas website. Build My Kubota - Product Selection I have 4240 and love it. What do you plan on doing with your tractor?
i never had vibations on the 3 cycl case i used to ran its was an 60.0 cu in if the smaller kubotas vibations problems am L series or a small case ih compact i had a case245 we put 10k+ hrs on it no engine problems
/ New tractor #16
What I was trying to say is a 4 cylinder diesel will usually run smoother than a 3 cylinder. Just like in a car a V8 is smoother than a 4 cylinder. A 4 cylinder fires every 90* and a 3 cylinder fires every 120*.
/ New tractor
That's the idea is to buy a tractor that I won't outgrow unless I win the lottery. If I understand correctly you can have the mid pto installed later on on a gl? And it can't be installed on the l series? The fel lifting ability is one thing that makes me like the l series tractors.
/ New tractor #18
I am not sure about the mid pto on the Ls. Really, if I had a nice RFM I would never use to mid-pto. I suppose it would be handy running a snow-thrower but I live in NC so that's a non issue here.
/ New tractor #19
I have the B3200 (11 months and 100 hours) and it is the perfect tractor for my needs. I wanted the mid PTO for possible future needs, but I will likely never use it as I have the rear snowblower and I don't mow with it. As this is my first tractor I didn't want to regret not having the future option somewhat like the OP.
Vibration - a little at certain revs but I found the 3200 I drove at the dealer smoother than the smaller 3 cylinder b's I looked at. I also looked at the L3200 but found it too large physically. I use my tractor maintaining ski trails on my property and anything bigger would not be maneuverable enough. A few well placed grommets on the FEL removed most of the rattles from the pins which was the most noticeable aspect of the minor vibration
If you have the budget and the physical size is not a problem you may be better with the larger machine. Remember the bigger machine will need wider implements to cover it's tracks.
Here's mine - Stewie
/ New tractor
I'm looking at the mid pto for future use also. I don't need it now but who knows what ones situation is years from now. For a couple of dollars more it might be worth it. I was thinking the L3800 but I here about all the jerky TPH stories. Havin used a machine in the past with a jerky three point I'd like to avoid it if possible. I could talk myself out of the mid but the TPH concerns me. Trying to get close on a price for a 3240 or 3540.
Does anyone know how far barlows delivers to? I haven't been able to get through by phone or email to those guys.
Thanks all
