New Shop Lights?
/ New Shop Lights? #1
monteu
NE Kansas
Kioti DK5010
I am wiring my 30' x 40' shop. The sidewalls are 14 ft. high. Any recommendations on what kind of lights I should put in? I really don't have any ideas. Is there like some kind of online lighting planner where you enter your dimensions and it tells you how far apart to space your light fixtures? I will be doing machine work in here. The ceiling will be white metal. Any ideas will be appreciated. Thanks
/ New Shop Lights? #2
Where do you live? How cold does your shop get? To me you put up as much light as you can afford, generally the flourescent tubes are the most cost effective and keep a good color range, but there are other alternatives.
/ New Shop Lights?
NE Kansas. Temp range is -0 F degree to 100+F.
/ New Shop Lights? #4
4 foot T-8 fixtures. Make sure they are cold start. Menards has these on sale periodically and they work great. Install a network of outlets on the ceiling, perhaps two or three rows with outlets every 8 feet in your case. You can then move the lights around or add extra ones where you need them. In your case, I would start with about 3 rows, each with 4 fixtures. That's about 0.5 watt fluorescent per square foot. That's what I have in my pole barn and it's fine but I'm adding an extra set to double that just over the workbenches. Try it and then you can add extra lights where you find they would be good for working.
/ New Shop Lights? #5
Do to goverment restrictions the 4ft fluorescents are no longer made.
/ New Shop Lights?
The lights I have seen at Menards are plugin. Is that what you are suggesting just put in electrical outlets?
/ New Shop Lights? #7
If you have a Home depot, go look at their display. The HO(High Output) tubes are the way to go, I put 4 pairs in my 30x36 basement and they are very bright. For a shop I would add two more pair.
/ New Shop Lights? #9
Like Wedge40, I have the HD 6 light HO fixtures in my 30x40 and they do a great job. I am going to add more as the money allows.
/ New Shop Lights? #10
/ New Shop Lights? #12
Yes, it may seem to be a little low tech, but having a network of outlets and using plug in lights, you can move them around and add additional lights with very little effort. For some strange reason, these plug in lights seem to often be cheaper than wire in versions and I don't see any downside to them as long as you get the cold start versions, which seem to have much better ballasts than the warm weather versions. I've bought them when the have the money back rebate promotion that makes them very economical.
I did my pole barn (40' x 48') with three lighting circuits. One controls lights in the shop/workbench area and near the overhead doors. A second covers the rest of the building which is mainly storage space. The third controls a separate set over the benches that effectively will double the light in the shop area when I turn it on.
I checked with some of my references and current guidelines seem to be (with T-5/T-8 lighting) 0.5 watts/ft2 in storage areas and 0.7 watts/ft2 in office areas. I've got about 0.5 overall and it seems to be OK, but I will add the third circuit lights and bring it up to over 1.0 over the workbenches.
/ New Shop Lights? #13
HUH????????? Maybe in Ohio but only Incandescents are currently on the chopping block... and only a limited number of them...
This from Wiki-
In December 2007, the federal government enacted the Energy Independence and Security Act of 2007, which contains maximum wattage requirements for all general service incandescent lamps producing from 310?600 lumens of light.[40] However, these regulations never became law, as another section of the 2007 EISA bill overwrites them, and thus, current law, as specified in the U.S. Code, "does not relate to maximum wattage requirements."[41]
The efficiency standards will start with 100-watt bulbs and end with 40-watt bulbs. The timeline for these standards was to start in January 2012, but on December 16, 2011, the U.S. House passed the final 2012 budget legislation, which effectively delayed the implementation until October 2012.[42]
Light bulbs outside of this range are exempt from the restrictions. Also exempt are several classes of specialty lights, including appliance lamps, rough service bulbs, 3-way, colored lamps, stage lighting, and plant lights.
The United States Environmental Protection Agency's Energy Star program in March 2008 established rules for labeling lamps that meet a set of standards for efficiency, starting time, life expectancy, color, and consistency of performance. The intent of the program is to reduce consumer concerns about efficient light bulbs due to variable quality of products.[32] Those CFLs with a recent Energy Star certification start in less than one second and do not flicker. Energy Star Light Bulbs for Consumers is a resource for finding and comparing Energy Star qualified lamps.
By 2020, a second tier of restrictions would become effective, which requires all general-purpose bulbs to produce at least 45 lumens per watt (similar to current CFLs). Exemptions from the Act include reflector flood, 3-way, candelabra, colored, and other specialty bulbs.[43]
In 2011, Rep. Joe Barton of Texas and 14 other Republicans joined to introduce the Better Use of Light Bulbs Act or BULB Act (H.R. 91), which would have repealed Subtitle B of Title III of the Energy Independence and Security Act of 2007. Barton was opposed to regulation, while Rep. Michael Burgess pointed to jobs purportedly lost to China and voiced a fear of mercury problems resulting from CFL use.[44] On July 12, 2011, H.R. 2417 failed to pass by the required two-thirds[clarification needed] majority in the U.S. House.[45]
/ New Shop Lights? #14
If that IS TRUE.... then WASHINGTON IS TRYING TO KEEP (put) U S <plural meanings meant> IN THE DARK!!!!
Buggers are SCR%$@*&ing us over in so many ways!!!
/ New Shop Lights? #15
This from Wiki-
Problem is By the time the bill to "Not to go after violators making bulbs was passed" MOST manufacturers probably had already retooled for pork barrel lights...
Has anyone noticed how short a life a new incandescent bulb actually lasts these days???
NOT made like bulbs were years ago... that lasted years......
CFL's ARE worthless replacements where; instant full light, short-term or cold temperature use
is needed.
CFL's have a place, but not all places are for CFL's
LEDs are not Cheap or a real alternative in a lot of cases either.
/ New Shop Lights? #16
This from Wiki-
Read this and post your I'm sorry I was wrong post. New light bulb rules go into effect Saturday - KansasCity.com
/ New Shop Lights? #17
Not only have they stopped making the bulbs, you can't use your ballast on the new approved bulbs.
/ New Shop Lights? #19
You think its GE ???? One of o'bummers friends.
/ New Shop Lights? #20
wow just thought of something ....
GET ready for a new government backed PROCESSED FOOD....
"SOYLENT GREEN"
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
Tree Boom Mini Skid Steer Attachment (A64553)
Tree Boom Mini...
2017 Maserati Ghibli Sedan (A64557)
2017 Maserati...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
