430 baler tying problems
/ 430 baler tying problems #1
gary d s
Choctaw, OK
430 John Deere
Hi, I'm Linda. I turned to this website for help since my husband is too stubborn. He ended last season with the baler working fine. This season it ties over and over in the same place and won't cut. He has replaced parts, greased and about everything that you would normally do. If you reply I think your comment will go to his email. Any suggestions?
/ 430 baler tying problems #2
Linda
The tying mechanism on a JD 430 rd baler is a little complex. First tell your hubby to be sure all 5 springs in attached photo are intact and attached correctly. Hay/debris can build up under parts key # 14 keeping spool valve from shifting allowing twine arm to move to the RH but not return to LH side to put twine on bale and cut twine. Also rust/debris on spool shaft of valve can cause problems. Back when 430's were new I sold and delivered them. Your hubby can feel free to call me at 8one7*five1seven-1five9zero and I will try to help him. Also I baled many bales with a 430 before I upgraded to a 435,then a 466,then a 467 in my 20+ yr custom hay baling career.
/ 430 baler tying problems #3
I am pretty familiar with the 430. Does it try to tie when the bale is about three feet around? This is a very easy and cheap fix. On the right hand side, open the door. Look below the twine box. Find an arm made from about one inch bar steel kind of behind the twine arm pump. It will have a slanted angle cut towards the front of the baler and the rear of the bar goes...who knows where. It is the bar that the manual tie rope connects to. Anyway, find that bar, There should be a little spring about 2-3 inches long holding pressure on the bar. It should hold pressure to make sure the bar slides back and latches after the gate closes. If it is gone or sprung, your baler will want to tie just as the bale starts forming. Look in your operators manual for pictures in this area showing the spring. It is hard to describe something that is probably not there.
/ 430 baler tying problems #4
levijames
A 430 can tie a 3 ft diameter bale every time even if spring you referred to is attached and not sprung if tying mechanism fails to reset because of an obstruction when tailgate is closed after bale is ejected.
/ 430 baler tying problems #5
I just bought a 430. I roll up around 1k bales per year
is it OK to pressure wash the whole thing, including inside the doors to remove debris and chaff?
Mine needs a good cleaning, but appears to be in good shape.
/ 430 baler tying problems #6
I would check to make sure that the spring bars that hold the hay down against the strippers isn't bent and catching the string as it travels across on it's way to the cut off. Something is stopping the string from aligning against the left side of the bale and lining up with the blade mechanism.
/ 430 baler tying problems #7
High pressure washing can lead to brg failure from water being pushed past brg seals. Blowing off with air is better choice for cleaning.
/ 430 baler tying problems #8
thanks Tx Jim
that makes sense to me.
I learned to bale on a 605C. Now am moving onto a 430jd. it is like going from counting on fingers to using a computer.
this will be an interesting season.
/ 430 baler tying problems #9
subscribed
/ 430 baler tying problems #10
Good Afternoon, I found this old post about JD 430 tying problems. I have a 530 doing a similar thing and I hope you can help or point me in the right direction. In the thumbnail you had showing the parts break down, #21 is not returning to the home position back under #14 after I dump a bale, I have to manually pull #21 forward towards the tractor about 1/4 inch before I start a new bale. I have replaced the springs, changed the filter, and check the fluid level. If I reset #21 back under #14, the tying arm will travel correctly, however I also have to apply pressure to the arm when it reaches the RH side to make it click and then travel back to the LH side. It will start to pull the knife blade down, but does not seem to have enough pressure to complete the knife cut. any ideas? thanks in advance Carl
/ 430 baler tying problems #11
Welcome to TBN
Are all 5 springs in place on twine pump mechanism? Have you liberally greased fittings(keys 48 &49) on twine gear assembly??
/ 430 baler tying problems #12
Tx Jim how did you like the JD 430 you had? I am thinking of buying one? I know this is a old post but I see we share the same area code.
/ 430 baler tying problems #13
Although it's been many yrs & rd bales made since I owned one, JD 430 rd balers are good balers except for the fact they came with single twine arm,no surface wrap capability or bale push bar. I remember demonstrating & selling them when they were brand new back in the early 80's. With a little ingenuity dual twine arms & bale push bar could be added to a 430. If bale core starting becomes a problem one needs to weld a bead on leading edge of each rectangular bar on starter roll to give roll more grip on hay. If possible open tailgate/LOCK OPEN with valve then check inside of bale chamber for holes worn in side sheets of baler. If your referring to the 430 rd baler located in Weatherford for sale on CL I think it's too high $$$$ for it's age. How many steps can you see on the tread on the bale forming belts?
I think the newer models with Mega-wide pick up are easier to operate & make a more level bale easier plus I prefer electronic operated wrapping over the hydraulic type such as the 430. Although IMHO a 466 Mega-wide pick up wasn't one of JD engineers shining moments as they leave a lot to be desired.
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2014 Ford F-550 (A55973)
2014 Ford F-550...
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
2018 Toyota Corolla Sedan (A61569)
2018 Toyota...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
