Post Hole Digger storage
/ Post Hole Digger storage #1
RunninOnEmpty
Kioti CK20S
We recently bought a Phd for the compact tractor & it's working out great. My question is: How does everyone store their Phd when not in use? Should I take it off & lie it down? Hang it from a stud in the barn? How long could I leave it hang on the back of the tractor? Thanks
/ Post Hole Digger storage #2
Dont lay it down to hard to put back on . I think the best way is to have two posts in the ground and hang it with PHD setting on cross post between up right post that can be removed . Just put it up high enought to backup to it and hook it up and then remove cross post and drive away.
/ Post Hole Digger storage #3
There are many options to store your post hole digger. I googled this since I just bought mine not too long ago. Some people just drill it in the ground a little and leave it there. Some hang it from a post in the garage or tree. I am going to make a stand outside for now until my shed is built that will store my attachments. It will be two posts in the ground with a board across the top and a hook to hang it from.
Here is a thread that has some ideas. http://www.tractorbynet.com/forums/customization/54029-post-hole-digger-stand.html
/ Post Hole Digger storage #4
Mine sleeps sideways on shop floor and on rare cold Fla nights I cover it with a blanket. ;) :)
Boone
/ Post Hole Digger storage #5
for now, i just pull 2 pins and then 2 bolts that hold the gear box onto the frame. which drops the PTO shaft, gear box, and auger bit. (gear box is the heavist) splitting them up i can man handle them and just lay them down on a couple pallets. but i really need to get a chain hoist and toss attach it to a beam in the shed. so i can just backup, hook up chain, undo hitch, and let it hang.
pending on how i am feeling / worn out, i may go as far as undo bolt were pto shaft hooks up to gear box, and then undo the shear bolt / pin that holds the auger bit to the gear box. to make things more lighter to move around. ya it takes a few more minutes to undo a couple bolts / pins. but not about to kill myself either. or need to take pain meds after moving it.
/ Post Hole Digger storage #6
Mine hangs from a small chain in the barn. I just wrap the chain around the frame near the gear box and slide a bolt through it to hold. I have plans to put a short piece of sliding barn door track up and hang the chain from that so the phd can slide out of the way.
/ Post Hole Digger storage #7
The PHD is easily the goofiest thing I have to store and hook up. By far the simplest way for me is storing it in a hole in the ground.
/ Post Hole Digger storage #8
I built a stand for mine out of 2x6s. I built it with the PHD in place. Now all I have to do is back the tractor into the boom, connect the top link and lift arm pins and I'm set. I have an F8 Danuser that weighs a ton. With the stand I can attach it myself. Oh, I always remove the auger or this deal wouldn't work.
/ Post Hole Digger storage #9
Thanks everyone, there are some good ideas here and I will try one in my new pole barn. I was looking for a way to store my post hole digger.
/ Post Hole Digger storage #10
Here's how I did mine, the pic doesn't quite show it all but the chain is simply suspended from a 4x4 piece of wood. There was already a thread about this same subject and it showed several ways to store a PHD. A little searching might find it.
Thanks for the advice, links & pics, very helpful!
/ Post Hole Digger storage #12
I bought a PHD last week, and I was wondering the same thing since it was a heavy nightmare to assemble, and put onto the tractor after I accidentally lied it down on the ground. I also need to build a hoist, or a rack for it. Thanks for starting the forum! This is my new PHD:
/ Post Hole Digger storage #13
How about this setup?
/ Post Hole Digger storage #14
Easily the most ignorant implement to store and remount.. here's what I did, copied from MtnViewRanch..
You remove the crossbar, back up, replace the crossbar, lower digger and pull the pins then drive away. No wrestling! The best part is using the digger to build the stand!
Sean
/ Post Hole Digger storage #15
It was built in place so I can back the tractor right up to it.
/ Post Hole Digger storage #16
I need to make one too.
I think I'm picking my PHD up today and I'll need a stand to store it on ummmmm Today also!
I have no space "inside", maybe I'll find a tree to hang it from, but I've got plenty of scrap lumber, so... beats me what I will end up doing...
Love looking at all the interesting ideas people have had!
Be well,
David
/ Post Hole Digger storage #18
You remove the crossbar, back up, replace the crossbar, lower digger and pull the pins then drive away. No wrestling! The best part is using the digger to build the stand!View attachment 273157View attachment 273158
Sean
My two stand holes were the first 2 holes that I dug with my PHD. ;)
/ Post Hole Digger storage #19
What brand pf PHD is it?
/ Post Hole Digger storage #20
Here's an easy and cheap way that will also keep it clean.
I used the digger first to open up a hole that I then made wide enough to bury an old tall plastic trash can in. Cut out the bottom of the trash can, buried it with about 8 inches of the top still showing, and filled the bottom 6 inches with rock so the auger tip sits on that and water can drain.
From there a couple of old blocks for the 3-point arms to sit on and a rubber strap to keep the pto shaft out of the dirt.
Easy, cheap, and quick and also allows for a fast hookup when needed because the weight isn't all on the top.
