What Hydro Fluid is needed for dk45sehst
/ What Hydro Fluid is needed for dk45sehst #1
kioti pup
Member
Dillon, MT
2011 Dk45se HST
Hi I have a dk45sehst and the manual says to use Mobil fluid 423 or 424, Exxon hydraulic 560, Shell donax-td, or BP Tractran UTH but none of these brands are available where I live only Cenex brand fluids are available does anyone know the right cenex brand of hydro fluid I can use? Thanks!
I think I got my answer it looks like AGCO 821 xl, JD 303 or IH hi tran would work. :)
/ What Hydro Fluid is needed for dk45sehst #3
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
Try these folks for the Mobil Fluid...You can get 10% off and free shipping from time to time which makes it a fair deal for that fluid.
/ What Hydro Fluid is needed for dk45sehst #4
The main properties of the hydraulic fluid used is a 10w-30 multi weight fluid that can handle gears, wet brakes, and hydraulic pumps. The Shell Donax TD had a name change to Shell Spirex. Another oil is Pennzoil Hy-Trans. Considering you are in Montana, I would assume Winter is cold. That's where the multi grade 10w-30 helps with cold temps. I looked at the Cenex site and they have a #46 hydraulic oil. I don't know how that relates to the weight of the oil. I'm sure if you ask where you buy these oils, they should know.
Thanks for the info I think I got it figured out your advice was very helpful! :thumbsup:
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
