What Hydro Fluid is needed for dk45sehst
   / What Hydro Fluid is needed for dk45sehst #1
kioti pup
Dillon, MT
2011 Dk45se HST
Hi I have a dk45sehst and the manual says to use Mobil fluid 423 or 424, Exxon hydraulic 560, Shell donax-td, or BP Tractran UTH but none of these brands are available where I live only Cenex brand fluids are available does anyone know the right cenex brand of hydro fluid I can use? Thanks!
I think I got my answer it looks like AGCO 821 xl, JD 303 or IH hi tran would work. :)
   / What Hydro Fluid is needed for dk45sehst #3
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
Try these folks for the Mobil Fluid...You can get 10% off and free shipping from time to time which makes it a fair deal for that fluid.
   / What Hydro Fluid is needed for dk45sehst #4
The main properties of the hydraulic fluid used is a 10w-30 multi weight fluid that can handle gears, wet brakes, and hydraulic pumps. The Shell Donax TD had a name change to Shell Spirex. Another oil is Pennzoil Hy-Trans. Considering you are in Montana, I would assume Winter is cold. That's where the multi grade 10w-30 helps with cold temps. I looked at the Cenex site and they have a #46 hydraulic oil. I don't know how that relates to the weight of the oil. I'm sure if you ask where you buy these oils, they should know.
Thanks for the info I think I got it figured out your advice was very helpful! :thumbsup:
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2019 International Bucket Truck (A55973)
2019 International...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
NEW Fork Extensions (A59000)
NEW Fork...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
