What Hydro Fluid is needed for dk45sehst
   / What Hydro Fluid is needed for dk45sehst #1
kioti pup
Dillon, MT
2011 Dk45se HST
Hi I have a dk45sehst and the manual says to use Mobil fluid 423 or 424, Exxon hydraulic 560, Shell donax-td, or BP Tractran UTH but none of these brands are available where I live only Cenex brand fluids are available does anyone know the right cenex brand of hydro fluid I can use? Thanks!
I think I got my answer it looks like AGCO 821 xl, JD 303 or IH hi tran would work. :)
   / What Hydro Fluid is needed for dk45sehst #3
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
Try these folks for the Mobil Fluid...You can get 10% off and free shipping from time to time which makes it a fair deal for that fluid.
   / What Hydro Fluid is needed for dk45sehst #4
The main properties of the hydraulic fluid used is a 10w-30 multi weight fluid that can handle gears, wet brakes, and hydraulic pumps. The Shell Donax TD had a name change to Shell Spirex. Another oil is Pennzoil Hy-Trans. Considering you are in Montana, I would assume Winter is cold. That's where the multi grade 10w-30 helps with cold temps. I looked at the Cenex site and they have a #46 hydraulic oil. I don't know how that relates to the weight of the oil. I'm sure if you ask where you buy these oils, they should know.
Thanks for the info I think I got it figured out your advice was very helpful! :thumbsup:
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
INGERSOLL RAND SD25F PADFOOT ROLLER (A52709)
INGERSOLL RAND...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
2001 MACK CX613 SLEEPER (A58018)
2001 MACK CX613...
