Building a Boom Pole - thoughts?
/ Building a Boom Pole - thoughts? #1
AmericanTractorDriver
USA
None
Hello,
Did a search but didn't see too much about this.
I think a boom pole would be very useful. Yes, I have seen the $75-100 ones on craigslist. However, they are usually beat up, bent up, and often light duty. I figured that I will try to find a cheap source for metal, and by manufacturing my own, work on my welding skills.
I'd like to build one loosely similar to the King Kutter HD model. If I find steel second-hand somewhere, do I need to be concerned about the grade? I assume a 3x3 or 3x4 tube is going to be sufficient as long as the metal is straight and not cracked or otherwise damaged.
Any thoughts or concerns about building my own boom pole similar to this? If anything, I will err on the side of extra metal and strength. Anyone know what thickness their tube is - maybe 1/4"? I will go with a minimum of whatever the commercial builders use to be safe.
Also - although I am not this far into the design yet - does anyone happen to have a chart showing the proper dimensions for 3-pt attachment points that are also QH and iMatch compatible? If not, I'll gather it all and put it together, but thought maybe there's a chart with all the dimensions in one place.
/ Building a Boom Pole - thoughts? #2
Knowing what little I know, I would think all of your question would be better answered by stating what you plan on lifting with it.
Anything that is within a reasonable weight limit... moving maybe lifting a 3-pt attachment off a trailer, maybe a moderate log (not huge tree trunk), a large piece of angle iron,...
Thanks.
/ Building a Boom Pole - thoughts? #4
the other question besides what you want to lift...is what size tractor will it
be mounted on?
a design thought,
would you want it to be able to lift higher than the
3ph allows? i.e. like a engine hoist (cherry picker),
or maybe be a fixed angle boom-
vertically adjustable with a pin to adjust for lifting off a trailer or out of a
pickup truck bed?
be mounted on?
a design thought,
pickup truck bed?
Aging,
Good thoughts. I wanted to build it to fit either cat I or cat II hitches. Other attachments do this with a dual clevis hitch arrangement.
I had not thought about using two pins to hold the boom in place, to allow for adjustment. However, I think that might make it weaker under side loads? I'm still thinking out loud here, and brainstorming.
/ Building a Boom Pole - thoughts? #6
Here is mine that I adapted for the front.
I can use it on the Power-Trac, or a tractor.
/ Building a Boom Pole - thoughts? #7
Real neat set-up JJ ! :thumbsup:
Here's pic's of mine.
Boone
/ Building a Boom Pole - thoughts? #8
If you want something simple and fast use a 6by6 or 4 by 4 box in both ends about a foot up both ends weld a hook on one end and a peice of angle with holes in it to bolt to the front bucket. The 4 by 4 I have will pick up more weight than you think and only have about 40 bucks in it.and takes about 30 minutes.
/ Building a Boom Pole - thoughts? #9
I also put a 2 in hitch tube on the end so I could use these.
/ Building a Boom Pole - thoughts? #10
I use a 3" tube 8 feet long with a 1/8" wall on my 1026r loader to lift 1000lb at the base, 500lb in the middle and 250lb at the end. These are tested weights. I don't know what the actual limit is. It is supported at 4 ft by chains that go to the bucket hooks. The base slips over the cutting edge. Very easy on and off!
/ Building a Boom Pole - thoughts? #11
Aging,
when I wrote about being vertically adjustable, I was thinking receiver hitch style
facing up square tubing steel. But a variation using round pipe could allow
side to side swing or positioning.
I'm going to try something here graphically with the keyboard ( might not be perfect)
3PH MOUNT
QI I top link
I O I boom static height adjust pin hole
I - I
I - I (base mounted on lower arms
I - I tall enough to mount to Top mount)
I - I
I___I
==== bottom hitch mounts
BOOM
I = I====================-D
I _ I
I OI
I OI ^
I OI v
I OI adjust pin hole to raise for occasional need
/ Building a Boom Pole - thoughts? #13
Search for and read the thread "Boom pole from TSC - Any good ?". Lots of ideas. Check my two photos. My pole is 6' and is extendible. AI paid thought to how to chain up to items and have a chain in a key hole that can not come out. It wont get lost. A receiver at the hitch side can use a trailer ball. I can pull a trailer while the pole is on the tractor, jack knife up to a load, pick up, and drive forward, leaving the load over the trailer. A second receiver, on the boom tip, can hold an extension. A hydraulic top greatly increases the boom tip lift. Made to fit an iMatch. Buy a QH and use it as a jig when you build. Easier than measuring, and useful.
/ Building a Boom Pole - thoughts? #14
JJ- didn't recognize you clean shaven and without a hat!........
View attachment 6191.pdf
From the North Dakota State University Extension site. Gives a good "base" design to add whatever you want to it.
I have found tons of ideas here and at several other extension service site. Some of these plans date back many years but, are worth looking at. Some you may find are better than what is available today.
Here are links to some of the other ones:
FAPRI - Food and Agricultural Policy Research Institute
UT Extension
UVM Extension : University of Vermont
MWPS: MidWest Plan Service, A Foundation of Knowledge for Agriculture
C.P.S. Plan Series Menu
Some of the same things appear on each site and some are quite lengthy. I have spent hours OOhhing and Awwing...at some of these plans. unfortunately, my wife thought (at first) that i was on "other" web sites ooogling at the "implements".:laughing:
/ Building a Boom Pole - thoughts? #15
JJ luv the flowing curves on yours.
What is the hydraulic fixture in photo 3 used for?
The hyd attachment on my boom pole is a tree or limb or root cutter.
Here is another one of my attachments built using box bld shanks.
/ Building a Boom Pole - thoughts? #16
I have a modified version of that 6191 that was originally built for a 60hp Massey. Far heavier than I need without a full bucket of sand to hold the front end down.
I have a 2" receiver on my FEL fork frame that I can slide in a section of 2" for tall (light) lifts as well. (Such as erecting TV towers)
/ Building a Boom Pole - thoughts? #17
some issues between a FEL (front end loader) and booms, cherrie pickers and like i have used in past.
wanting a hand crank winch. hand crank like you might find on a trailer for a boat. were you can back trailer down into the water. then pull the cable out, hook to boat. then crank the boat up onto the trailer. but for a boom pole. being able to have a pulley at the very end. and hand crank near the base / 3pt hitch. so i can easily reach down over something.
lift height, as in getting a fridge, that is standing up right in back of a truck.
lift reach. trying to backup and trailer and tractor being at odd angles and trying to get reach, to little over middle of trailer. i may end up having less physical lift capacity with a longer reach boom pole. but being able to just lift up enough weight on an implement, that i might be able to push or simply drive trailer away and let implement scratch and slide its way off.
long reach, for myself would come in handy, when it comes winter time, and pulling out the paddle boat, and row boats. out of the lake. and not having to pull them up on dry land to hook them up. to lift them up vs just dragging them.
being able to turn the boom side to side. more so when loading a trailer. to backing up to an area say in the shed, and object is heavy enough, that trying to man handle the object to move it, is out of question. being able to swing boom side to side, would really help. it is when ya get tractor position just right, but off them 1/2" or couple inches, were trying to physically push or pull object over via second person and then dropping object slowly can be down right dangerous to almost impossible.
a boom pole that has multi connection points, so i can lift heavier and heavier objects. the closer i connect chain to the 3pt hitch. would be great.
trying to skid a log, i just put draw bar on, and run chain right around draw bar and end of log. in order to have max lift capacity, and keep the weight as close to rear tires as possible. so front wheels of tractor stay on ground. vs doing a wheely.
below are just various links, that may give you something to think about. along with looking up specs, of various sizes of how much they can handle.
Pickup Truck Cranes + Truck Jib Cranes | Hoists, Lifts + Cranes | Material Handling | Northern Tool + Equipment
Mounting Frames | Hoists, Lifts + Cranes | Material Handling | Northern Tool + Equipment
Manual Cable Hoists | Hoists, Lifts + Cranes | Material Handling | Northern Tool + Equipment
Manual Gear Chain Hoists | Hoists, Lifts + Cranes | Material Handling | Northern Tool + Equipment
Manual Lever Chain Hoists | Hoists, Lifts + Cranes | Material Handling | Northern Tool + Equipment
Hand Winches + Boat Winches | Winches | Northern Tool + Equipment
Beam Tongs + Lifting Tongs | Hoists, Lifts + Cranes | Material Handling | Northern Tool + Equipment
above link. tongs (there is better name for them) for putting on a log and hooking to back of 3pt hitch directly.
Vestil Winch Operated Truck Jib Crane — 500/1000-Lb. Capacity, Model# WTJ-2 | Truck Cranes| Northern Tool + Equipment
if i could find something like above, as a 3pt hitch boom pole. you would have to pry it out cold dead hands.
/ Building a Boom Pole - thoughts? #19
Boggen
Here's some pic of my attempt
Forget a hand crank, I got a 12vdc 1 ton winch from HF.
Unloading shipping container
placing roof panels
moving 8x12 4000 gal tank
placing 25ft roof panels
David Sent from my iPad using TractorByNet
/ Building a Boom Pole - thoughts? #20
...being able to turn the boom side to side. more so when loading a trailer. to backing up to an area say in the shed, and object is heavy enough, that trying to man handle the object to move it, is out of question. being able to swing boom side to side, would really help.
Be careful with swing capability. If the tractor isn't level, when you lift something on the high side, it will swing quickly to the low side as soon as it is clear of the ground. Your swing motion needs to be lockable and controllable.
Bruce
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
John Deere Mirrors and Light Kits (A63116)
John Deere Mirrors...
2008 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A61568)
2008 Chevrolet...
