What is BX23 fuel consumption while running a PTO generator ?
/ What is BX23 fuel consumption while running a PTO generator ? #11
My understanding is that most tractors governor will hold the hertz very close to the required 60HZ. Hertz (frequency) is the component of the electricity that would be affected most by the PTO speed varying to much. Only if you exceed the PTO HP would the tractor PTO slow down. I do not have a PTO generator...........yet. So if you take my info here and add $10 to it you could likely go to any city in the country and buy a cup of coffee.:D
/ What is BX23 fuel consumption while running a PTO generator ? #12
Attached is performance specification sheet for your engine, which includes fuel consumption curve. With this, and a little work, you can get a baseline gallons per hour for your conditions. Philip.
  • 05_d902_32.pdf
/ What is BX23 fuel consumption while running a PTO generator ? #13
How much is your guy's tractor bogging down under load with a PTO generator? I envision if the tractor is running at PTO speed (roughly full throttle on most tractors) to supply the correct voltage to the generator, the tractor shouldn't bog down unless generator is overloaded. But then again, shouldn't the generator's circuit breaker trip?
If the engine bogs down then you wouldn't get the correct voltage from the generator. Most basic tractors don't have an automatic governor to keep rpm's up under load. So if your operating within the limits of the generator, shouldn't you burn the same amount of fuel as you would running the tractor at or near full rpm's without the use of a generator?
Its my understanding that most tractors do in fact have a governor, so at the load increase, so does the fuel consumption.
/ What is BX23 fuel consumption while running a PTO generator ? #14
Every tractor I have seen has some type of constant speed-vaiable load mechanical governor, they have to. Some are not as responsive as others, but as long as you have a little excess engine horsepower and match your electrical consumption load to the generator output, you should not have any problems. Most all pto generators I have seen have a frequency meter on them. Set you pto to speed to 60 hertz on the frequency meter under normal load and all is good. Philip.
/ What is BX23 fuel consumption while running a PTO generator ? #15
Then why does my tractor or most bog down, lose rpm's when bush hogging and I never see my rpm's raise until heavy load is no longer a strain. (Thick grass etc). I see a heavy a heavy electric load doing the same thing. Heavy load, engine and rpm's bog down until load is decreased or gone. Maybe I'm not understanding something here??
/ What is BX23 fuel consumption while running a PTO generator ? #16
Tractors and most mechanical industrial engines have droop style governing. Most all generators have isocronous governing. Droop governing allows a percentage of rpm rise or droop before the governor takes over, this is easier on mechanical parts and better fuel consumption. Isocronous governing, used mostly for generators to hold a tight 60 hertz, allows almost no change in rpm, is harder on mechanical parts, and has worse fuel consumption. If your engine bogs down to a point where the governor cannot keep up, you are over loading the engine beyonds its rated output. Philip.
/ What is BX23 fuel consumption while running a PTO generator ? #17
The reason I'm asking is I've got a lot of fuel oil for heating purposes but I usually run a pellet stove.
So far I've always been able to get gasoline and I run a EU2000i generator 24 hours a day for heat and light.
But to bring up water and other things I need a bit more power.
And if I ever can't get gasoline I'd love to be able to use the tractor.
Larry
FUEL... I don't know if I'm reading what you wrote correctly, but if I am, I want to say this (even though I am NOT an expert):
Fuel has been changing ALOT this past decade. It's not like it was 30 years ago. You can NOT run heating oil in a diesel truck (or tractor???), made after 2007.
#2 heating oil is HS (High Sulfer). My limited understanding is that Diesel used to be HS also. It is not anymore.
Diesel became LS (Low Sulfer) at 500 ppm (parts per million) sulfer content. Well, in 2006, it changed again...
Diesel became ULSD (ULTRA Low Sulfer) at 15 (parts per million) sulfer content.
SO... if your tractor engine is designed to run on ULSD (Ultra Low Sulfer Diesel) and you put #2 heating oil in it.... well, you may be all done with your tractor after that.
Heating Oil and Dyed ULSD are not the same thing.
If your furnace oil company is delivering Dyed ULSD, then you could use that in your tractor.
Just be careful.
NOTE: If there is an expert, in Petroleum, that knows something more accurate than what I wrote, I would appreciate being corrected.
/ What is BX23 fuel consumption while running a PTO generator ? #18
Just be careful.
Check with your distributor about this. VERY rare is the distributor who still sells anything BUT ULSD to the end user, so in MOST cases, dyed ULSD and HHO are the same thing.
There are several threads on this with EXCELLENT citations in the "Oil, Fuel and Lubricants" forum.
Aaron Z
/ What is BX23 fuel consumption while running a PTO generator ? #19
Rare? Not in Maine or NH. I know in Boston they were starting to just use dyed ULSD, but I don't know that all terminals in Boston switched. Are you sure that #2 heating oil is rare for home delivery?
Are all of u already filling your tractors from a furnace oil tank???
I have #2 fuel oil delivered to the house. It would cost me more to have dyed diesel delivered to my house than what I pay for clear diesel at the station.
In Maine, NH, and VT (I think) they are very, very different fuels.
/ What is BX23 fuel consumption while running a PTO generator ? #20
Gehl 125 Mix-All (A60462)
Gehl 125 Mix-All...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
1999 John Deere 7810 (A60462)
1999 John Deere...
CFG QK20R (A60463)
CFG QK20R (A60463)
Mahindra 3550P (A60462)
Mahindra 3550P...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
