JD 755 injector question
/ JD 755 injector question #1
bluffdale
Bluff Dale, TX
JD 5225, 755
One of the three injectors on my JD 755 is leaking. When I replace it, should I go ahead and do the other 2.
/ JD 755 injector question #3
i see you are fairly close to ft worth there is a company lone star fuel injection 817-625-5388 they should be able to get you new aftermarket or possibly a reman one. your john deere number should be am879688 good luck
Thanks. Is there any real difference in new versus remanufactured assuming the remanufactured item is of good quality.
/ JD 755 injector question #5
i have always been a firm beleiver that the best reman products is one that is built from an original core or a very good name aftermarket case in point recently needed an injector for a cat motor new cat was 600.00 got a reman cat for 350.00 and always have your core with you if there is one alot of times the core for diesel parts is double what you pay for the part on the injector i got it was 750.00 more than double
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
5' Bush Hog (A62613)
